-   -   More Coldstart Problems (http://www.aleromod.com/forums/showthread.php?t=28023)
Nate's Alero 07-21-2009 12:59 PM
Here are some video's to clarify my problems with the car, here is a starting, walk around, exhaust and driving video's to show EXACTLY what the car does...
i want it fixed. im not selling it, dont waste your time by telling me its done or whatever, if it needs a motor or whatever, it will get one. please do not say i need to sell, get rid of, or destroy. i will have your post deleted. thanks :)
Youtube Links
http://www.youtube.com/watch?v=jMznwlmf6Lc
http://www.youtube.com/watch?v=p2mKr...e=channel_page
there will be one more later, but its taking forever to upload
I just dug this up, i think this is when it started having slight coldstart problems, they got worse over time
http://www.youtube.com/watch?v=pxjsC...e=channel_page
Now playing: Lacuna Coil - Swamped
via FoxyTunes
thats a neat feature.
Ryan from Ohio 07-21-2009 01:29 PM
Give this a whirl. Just humor me here.
After letting it sit for 2-3 hours, press the valve on the fuel rail to check the fuel pressure that is residual. Dont start it, dont put the key in the ign. Just pop hood and press the button.
I think you are getting air into your fuel line...
And BTW... Stop being a drama queen... lol
Nate's Alero 07-21-2009 01:31 PM
hmmm, i will be sure to do that, im going to work now, and ill come back and see what happens, that seems likely though, as thats how it starts, if it DOES have air in the fuel lines, what should i look into next?
(as i use up the gas in my tank, it gets harder to start)
Ryan from Ohio 07-21-2009 01:35 PM
Did you replace the fuel pump? The fuel filter? Did you disconnect the fuel rail ever?
If you did any of the above you may not have got the seal back fully. In which case air could get into the mix.
Its possible but not highly probably.
But if its not checked, you cant rule it out.
There should be a round valve on the end with a plastic cap. Just take it off and depress the pin. Gas should shout outta that bastage pretty good. If it spits, sputters or doesnt fly out, you have a fuel problem.
Nate's Alero 07-21-2009 02:19 PM
i have done the LIMG, discoed the fuel rail...
right now im waiting for a smoke fest :) Seafoam FTW!!
Ryan from Ohio 07-21-2009 04:03 PM
Seafoam isnt even half of what GM Top End Cleaner is.
Next time buy the good shit!
Nate's Alero 07-21-2009 07:18 PM
seafoam did the trick though.....
Ryan from Ohio 07-21-2009 09:20 PM
Seafoam cured your rough start?
lord2heart 07-21-2009 10:26 PM
hmm never heard of GM top end cleaner, i'l have to try it, i'm guessing you can buy these at advanced auto parts?
CactusWill 07-21-2009 10:37 PM
No, you buy it at the dealership. I was there earlier, I think its 7.95 or something.
