-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   LIMG Leak (http://www.aleromod.com/forums/showthread.php?t=28130)
twagn 07-29-2009 11:41 AM
LIMG Leak
A mechanic informed me of the bad news today but he "says" most of the leaks he's repaired (@40) don't leak coolant into the crankcase. True or false?
Thanks
cherrington17 07-29-2009 11:46 AM
eventually they do. he might just be catching them before they progress to that point.
Nate's Alero 07-29-2009 11:48 AM
mine did, with NO external leak. mine was so bad i poured the entire rad into the crank in like 10 minutes.... i did it it was easy. if you have watery oil, before you put it back together, clean the lifters, or the same thing will happen to you as to me, it held my valves open enough to simulate no compression.
zzyzzx 07-29-2009 12:20 PM
How many miles are on the car?
Exactly what does (@40) mean? I'm sure it's some sort of typo.
cherrington17 07-29-2009 12:28 PM
i'm pretty sure he means @ = approximate.
to clarify:
@ = AT.
~ = approximate
from a symbolic standpoint.
AGT 07-29-2009 01:00 PM
to clarify:
@ = AT.
~ = approximate
and 40 meaning the mechanics age...i think haha
cherrington17 07-29-2009 01:02 PM
approximately 40x hes done the job. :lol:
just throw in random mechanic facts..
I need my limg fixed. My mechanic says so. Hes 40yr old, likes walks on the beach. It isn't leaking into my crank case. Is it common for it to happen? Hes also a scorpio
AGT 07-29-2009 01:03 PM
Random fact: You ass... :lol:
So are you gonna have him do the fix....How much he quote ya?
twagn 07-29-2009 01:29 PM
He's repaired 40 lower intake manifold leaks and wants $800 to perform the deed. He says Dex-cool causes the problem to begin with. The car has 113k
Cliff8928 07-29-2009 02:07 PM
It's not necessarily the fault of the dex-cool.. It's the combination of the type of plastic in the gaskets with the organic acids in the dex-cool.
AleroB888 07-29-2009 02:10 PM
I would drive there and do it for $800.00.......:lol:
If I wasn't up to my ears in overtime hrs. right now.
zzyzzx 07-29-2009 02:55 PM
I was thinking that the mechanic found 40 leaks in your intake manifold gasket.
twagn 07-29-2009 03:07 PM
Isn't dex-cool reformulated now? Which makes it better than the original? Anyway, He wants to use the plastic type gaskets and change over to green coolant. I don't think plastic gaskets are the best replacement from what I've read on this forum.
It's a very slight leak at this point but a leak none the less. I'm going to keep an eye on it for now cause I can't swing the $800 to have it repaired.
twagn 07-29-2009 03:10 PM
You sure about that? I'm about eighteen hours from Denver:lol:
AleroB888 07-29-2009 03:24 PM
I made it to KY in just over 19. But it IS downhill.... :lol:
surreal_awakening 07-29-2009 04:19 PM
Just posted in another thread on the same topic....
http://wot-tech.com/shop/all/large-p.../prod_118.html
Use that, not the plastic ones.
twagn 08-03-2009 05:56 PM
Put an add on Craiglist and found someone who will do the job for $300 and I provide the parts ...gasket set from wot-tech:cool:
buickboy71 08-08-2009 09:35 PM
3400 Limg
If you drive to Jeff City I would do it for $250 if you provided the parts. I've done over 100 of these now.
