235/40/18
Will these fit our rears?
Considering it's very slightly smaller in diameter and slightly bigger in width than stock, yes.
yes........
heh......not mine, but might fit yours. Bend over and give it a try. But seriously, I don't think you'll have much difficulty, but check the inset on the rims for clearance on the spring perches. Any tire shop worth it's salt will be able to answer that for you. |
thats the size tires i had on my 18s. perfect fit with a +42mm offset.
yeap it fits, luckily with about 5mm of clearance if im lucky lol
yea i could barely fit my pinky between the tire and spring perch.
hmm, must be the offset of your rims....mine fit no problem......
