ok i need some help with this one!!
ok i'm having the problem with my coolent getting pushed out of the overflow now i know all the common things that make it do that lmg heads ect. heres thing when i bleed the coolent system i get the air out then i let it run and heat up and when i go to bleed it again nothing comes out no air or coolent thats what has me puzzled. can someone help me with this.
stuck thermostat?
just rethought, that, don't think that could be it if you are able to bleed it once. So to clarify when you are at a running temp of about 190 or 200 the system won't bleed? When does it bleed? With car running at temp, open the bypass bleeder, Start pumping the hose coming out of the thermostat. If it's hot coolant is coming through the thermostat. If could, the thermostat is either stuck shut or big air pocket. Try pumping a squeezing a little bit more to get the air pocket out (if their even is one) Just try and get as much diagnostic info of the problem on this thread so it's easier to pinpoint But it does sound like the cooling system is getting pressurized by a leak. |
are you using the bleed off on top of the therm housing I had to open and close mine prob 10 times to get all the air out? sounds like a stuck thermostat to me.
its not the thermastat i just put a new in. and im using the bleed thats above the water pump its bleeds fine untill it gets about half way on the temp gauge then it want do any thing no air or coolant is that normal
oh yea i check the water pump and its fine no problems there.
Did you put it in upside down by any chance?? |
is you lower radiator hose collapsing?
upside down now there a thought. and no my radiator hose is not collapsing
