Gas gauge
So a couple of months ago when I started my car the needle on the gas gauge somehow went above the little tick at the top and has been stuck there ever sense. Any ideas on how to fix it??
sounds like sending unit is dead... |
Yeah, I would second Nate on that one....
wait, the little retainer at the top! oh! listen, remove the bezel, remove the cluster, remove the glass (about 12 clips) and Just pop the needle down below it
take the gauge out, pull the needle off, put needle back on. fill the tank, readjust the needle so its on "Full" reassemble gauges.
So his gas gauge had a Boner???:lol:
Ill keep putting that same gas. |
Yep you have what happen to me the sending unit failed, and you have to replace the whole thing , drop the tank and drop in a new unit ..If your having some else do it , It will take a day to do it. |
And hour for you what are superman??? BULL! It took me 3 hrs using jack stans and that pull it out and reastall the tank. In the book it a 4.5 hours for and alero tank removal and restall...that having a lift and trans jack to pull the tank down. I've done a tank job (fuel pumps) so :coolio: many time i lost count. |
^well, yea i guess with jackstand it would take longer. I used a lift with a trans jack to lower/raise the tank. Also my dad helped, and he had just done one earlier that day. it went quick
so who wants to do it for me haha :)
If you pick me up I will.
From Kansas damn dude I guess im goin to a shop
dude disconnect ur batt. and re-connect it. evry time i do all my needles sweep forward and go back to where they belong. cant hurt to try
If you drove down to my house i'd do it, for a price :p |
if you have access to a lift its like a 1.5 hour job, nothing major besides dropping the tank, its easier if you do it on a low tank because then its less weight to drop and less chance of you spilling any gas
