-   How-To Archive & FAQ (http://www.aleromod.com/forums/forumdisplay.php?f=14)
-   -   driver window (http://www.aleromod.com/forums/showthread.php?t=31212)
aleromiester 04-22-2010 06:17 PM
driver window
i noticed my window seems as if it keeps coming of track. so i took a look at it after i took the door panel off and found one of my window sash clips was broken off near the bolt. i went out and bought a pack of them and go to work at it today. i noticed that the RTV of some strong ass glue held the broken sash to the window. any advice? maybe get some heat to it?
redrider07 04-22-2010 09:02 PM
Mine did the same thing...broke off above the bolt. I went and bought a two part epoxy from Home Dept and it worked fine....just put a lot in the grove and it will hold fine. I pulled the window out and then used a heat gun to get the white piece of the glass, scraped off the residue and cleaned up before putting back in.
redrider07 04-22-2010 09:03 PM
meant used a heat gun on the white piece of plastic on the glass!
aleromiester 04-26-2010 06:46 PM
how long did it take you
