-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   Getting SVS, Trac Off & Anti-Lock (http://www.aleromod.com/forums/showthread.php?t=31898)
brycealero03 07-16-2010 09:36 PM
i got a problem with my alero gls and it seems to happen everytime i go from reverse to drive... it kinda like stutters when i hit the gas then it stops then i get the service vehicle soon, anti lock and trac off lights all come on....
anybody know whats going on?
i think this happened before when i got the car but dont remember what had happened..
thank you
2001 3.4L 07-16-2010 09:59 PM
sounds like something with the ABS..... i would look at that.
02AleroEco 07-16-2010 10:05 PM
I had that same issue. Turned out to be a clogged cat. hasnt happened since i got the new cat
brycealero03 07-16-2010 10:25 PM
How much is it to get that fixed
BlackJack 07-17-2010 01:21 AM
Probably not the case here, but check into your wheel sensors. My daughter's is doing the same thing with SVS, Track-off, and ABS lights.
The sensor provides input the computer uses to trip the second two of those, the SVS just means "get it fixed".
whiterider00 07-17-2010 02:18 AM
ya...its been covered dozens of times on here. mine does the exact same thing. either the sensor or wires going to it.
alerogls001 07-17-2010 02:20 AM
Yep. Mines been doing it for months. I am checking out the wires tomorrow while doing an oil change. Bought grease for after I clean out the connectors. See if that helps first.
