-   -   Accidently pulled out the driver-side output shaft on transmission. (http://www.aleromod.com/forums/showthread.php?t=32093)
Robb235 08-15-2010 05:56 PM
So for those of you who read my previous thread, I had my driver side axle come apart on me while driving. Today I started working on the car again, and the tripod section of the cv axle was still stuck inside the transmission. I tried for several hours to get it out of the transmission, but no luck. Finally I forced the issue and pried on my pry bar as hard as I could and out popped not only the tripod, but the output shaft still attached to it.
My first question is, have I seriously damaged the transmission by doing this? I'm not very educated when it comes to automatic transmissions. Secondly, how do I seperate the tripod from the output shaft? And third, what is the correct way to re-install the output shaft?
colonel6632 08-15-2010 07:15 PM
tripod what now?
Robb235 08-15-2010 07:22 PM
Maybe I'm calling it the wrong thing. The part of the cv halfshaft that actually hooks into the transmission.
cavaliers60 08-15-2010 09:10 PM
If you don't know what you are doing, you should probably have a mech fix it for you before you really screw something up...
Robb235 08-15-2010 09:55 PM
Quite a bland "one size fits all" response. There's no better way of learning than to actually do it yourself.
colonel6632 08-15-2010 10:22 PM
Originally Posted by Robb235 (Post 552625)
Quite a bland "one size fits all" response. There's no better way of learning that to actually do it yourself.
agreed. if i had that mindset, i wouldn't of changed anything on my car myself.
anyways. did you just pull the axle out of the side of the tranny? if so, i doubt you did anything bad. i've done it multiple times when i changed my seals there
Robb235 08-15-2010 10:29 PM
I broke the cv axle so it needed to be removed. When I tried removing it, it didn't want to disengage from the transmission. When I forced the issue, the cv axle finally came out, but with the output shaft still attached to it. I wish I hadn't cracked my digital camera, but here is a cell phone picture:
On the right side is what's left of the cv axle. The long rod is what the axle connects to when you put it into the transmission. The rod is inside the transmission itself, and I believe it connects to the differential? Like I said, I'm kind of a newb when it comes to transmissions.
Ttop191 08-15-2010 10:31 PM
guiguilandry 08-15-2010 10:57 PM
Originally Posted by Ttop191 (Post 552631)
WOW GREAT JOB.... I HOPE YOU KNOW A GOOD PLACE TO GET A NEW TRANSMISSION... SERIOUSLY IT IS THE FIRST TIME OF MY LIFE THAT I SEE THIS HAPPENING!!!!!!!! BUT DON'T PANIC JESUS IS WITH YOU...
Robb235 08-15-2010 11:09 PM
Yeah, thanks...
I'm not sure what else I was supposed to do. The cv axle will not, and still has not seperated from the output shaft.
cavaliers60 08-15-2010 11:15 PM
I was just saying.... If you don't know what you are doing, might have a mech help or something.... Otherwise you could really screw something up... I know this from experience. lol Just trying to save you from having to fork out extra money if you f something up. :lol:
guiguilandry 08-15-2010 11:16 PM
I'm a mechanic myself but.. seriously i've never seen this and i don't know very well the automatic tranny on our cars... both of mine are 5 speed... How is the shaft in the transmission holding by a clip ?? it is supposed to be mounted on a bearing pressed into the casing near the opening on the side.... maybe you'll be good if you're able to get it out of the tripod... that was the good name BTW
Robb235 08-15-2010 11:41 PM
So once I get the tripod/cv axle seperated from the output shaft, can I just line up the splines and tap it back into the transmission?
tunerkid 08-15-2010 11:57 PM
either way the auto tranny on alero's suck
GM came out with there "maintainence free transmission" literally no such thing.
if i were you i'd head down to a junk yard or something to just get one there. only drop some money on the tranny setup if your doing a swap
Gr1m 08-16-2010 12:06 AM
not sure what your talking about...the end with teeth on it that goes in the transmission is part of your axle and is supposed to come out when your pry it...just buy a new axle they are cheap after the core charge, and pop the new one back in to the tranny and you will be fine.
heineck 08-16-2010 02:11 AM
So the middle separated from the end goin into the tranny? U didn't eff up the tranny. Just get underneath it and pull it out. Are u doin this at home? Its a lot easier if u have access to a lift. Just go under and use sumthing like a pry bar and it should come out. And for future reference don't tug it from behind the inner CV boot. Btw u did rip the inner boot right?
Robb235 08-16-2010 07:53 AM
#26 is what came out of the transmission, still attached to the cv axle.
guiguilandry 08-16-2010 08:58 AM
you can try to put it back in but i really doubt that it will be ok.....
Gr1m 08-16-2010 09:05 AM
you must have done something seriously wrong to do that....
widbyj 08-16-2010 10:53 AM
Actually, both of the output shaft pieces CAN come out. This happened to my mechanic when he removed a "new" trans that was defective. The trans was a full rebuild from GM, expensive, and never did work right - low pressures. When he went to pull it after less than 200 miles of lameness, both of those shafts came right out along with the CVs. Dealer was sorta surprised to see that but they DO slide back in easily. Personally I think GM tried to sell me a used trans that was just cleaned, not rebuilt. Anyhow, you can re-install the shafts and nothing is seriously broken. Start shopping for a replacement though....
