-   -   HID troubles (http://www.aleromod.com/forums/showthread.php?t=32180)
alero_bmxer 08-28-2010 03:45 PM
HID troubles
so in the past month or two i have gone through 3 ballast's on just the driver side alone. my passenger side ballast is the one i have had in there since Christmas and that one is doing just fine. last night i flipped my lights on and my driver side light flickered and went out and wont come back on. i replaced the plug for the bulb last week because on the old one the tab was broke or missing and the harness wouldn't stay on. both bulbs are the original ones from Christmas time and neither one is burnt out so i know thats not it. any ideas at all? this is getting pretty annoying.
Ryan from Ohio 08-28-2010 03:58 PM
Where did you get the HID's from?
alero_bmxer 08-28-2010 03:59 PM
a local car accessory shop. they have warranties on the ballasts so its not a huge deal just kinda annoying.
robalero 08-28-2010 04:09 PM
what kind of hid kits are they? that doesn't seem right at all and seems like a manufacturing issue
mfuller 08-28-2010 05:33 PM
Are you absolutely certain it's the ballast?
Are you using a dedicated wiring harness with a relay (to pull juice straight from the battery) or factory wiring?
alero_bmxer 08-28-2010 05:44 PM
problem solved one of the connectors from the harness wasn't plugged in all the way haha. thanks though guys
cavaliers60 09-04-2010 08:46 PM
yeah... I'm having troubles with my HID kit I got from Ryan.... Lost one ballast because it had a lot of water that somehow got in it... Now the other one isn't working. I know it's the ballast because I plugged my regular bulbs in to the headlight unit and it works perfectly... Seems as though I must have gotten a bad kit... I'm just frustrated and would rather not deal with it....
Ryan from Ohio 09-04-2010 09:09 PM
I understand your frustration.
johnathanmpt 09-05-2010 03:15 PM
I have been lucky with the kit i got from this guy off craigslist for $65! Did anyone else have to run new wires for you headlights so you could mount them in a safer place?
robalero 09-06-2010 07:32 AM
nope, they were fine just being hidden under the headlight
