-   -   can you raise the voltage at the regulator?? or ECM?? (http://www.aleromod.com/forums/showthread.php?t=32792)
scott192 11-09-2010 11:30 AM
well im not impressed with 13.5 - 13.9v im lookin for 14.5 -15 alot more potential energy!! anyone know any tricks!! :coolio:
Cliff8928 11-09-2010 01:44 PM
There's plug-in solutions to modify the voltage output of the alternator... I don't remember where, but I've seen them before.
zzyzzx 11-09-2010 02:49 PM
Run heavier wire between your alternator and battery.
jayson_waltz 11-09-2010 04:09 PM
13.5 seems weak even for stock. Stock mine always put out 14.3-14.7, well it had a napa reman alt but it was just a stock replacement.
cherrington17 11-09-2010 05:28 PM
overdrive pulley. contact ryanfromohio he can get you in contact with a guy that sells them.
I've had one for a while, and its great.
BUT, everything in the car runs on 12V... using 13.5 or 14.8 really doesn't make a big difference
scott192 11-10-2010 01:38 PM
a .5 volt difference is HUGE when it comes to car audio alot more potential energy and alot less likely for my amp to go into protect mode thats why im lookin to raise the voltage
Monza 11-16-2010 03:06 PM
I think the output voltage varies based on the state of charge in the battery. Forcing a higher voltage may cook your battery.
jabartram 11-16-2010 04:18 PM
ZZPerformance
http://zzperformance.com/grand_prix/...=517&catid=108
scott192 11-19-2010 02:46 AM
it has more to do with the temp of it and im trying to figure something out to cool it better cause you could cook an egg on that sucker and yes i have ran bigger wire that did a whole lot of nothing lol need a H/O alt to see any gains from a bigger wire... adding a second batt seemed to help the voltage from dropping to low but id still like the extra juice!
Cashdollar2009 11-19-2010 06:36 AM
Deka 9a31 or Kinetik HC1800.
Selling both currently. Stock alternator, two runs of 2/0 welding cable to rear, 2/0 welding cable for big three. I am running 2.5-3k and dropping to 13.8ish at idle, never below 14.xx while driving. :) These batts must be magical? lol
cherrington17 11-19-2010 07:39 AM
Originally Posted by jabartram (Post 565319)
and just how exactly is that suppose to work? Like... what is in that harness??
Cliff8928 11-19-2010 12:53 PM
I do believe that it drops the voltage that the voltage regulator sees, so it thinks it has to put out more.
G.I.Ceo 11-29-2010 05:35 PM
This is a plug and play piece. I just bought one and installed it because I was having voltage drops after installing a UDP. As soon as I started the car I got a 1.0v and a little higher increase with it plugged in. It took me like 30 seconds at most to install this too.
Ttop191 11-29-2010 06:49 PM
So it must just be a plug and play resistor to block whats going to the sensor?
zzyzzx 12-01-2010 09:18 AM
Just reviewed the website and I think it's a great idea!
Gr1m 12-01-2010 09:29 AM
i have one of those boosters but i took it out because it actually works and my voltage was around 15 and didnt want to damage anything
scott192 12-01-2010 12:14 PM
how much u want for it?
Gr1m 12-01-2010 12:26 PM
i believe i have the stage 2 one, i have to check if its still in my toolbox
