-   -   Doors Freezing... (http://www.aleromod.com/forums/showthread.php?t=33040)
Philbar71 12-13-2010 10:28 PM
Doors Freezing...
So when it rains/snows then the temps drop well below freezing my doors get frozen in place. To the point where sometimes I have to pry on the door frame while opening trying to open it to break away the ice. It's not like the ice is on the outside its all on the part that the door comes in contact with the roof, the door jam part. It's extremely annoying.
Anybody else have this problem, or does my Alero just not like cold...?
[ion] C2 12-13-2010 10:32 PM
dielectric grease on the weatherstripping
mine gets stuck too
Philbar71 12-13-2010 10:46 PM
Hmmm. Thats an excellent idea!!! Thanks man!!!
colonel6632 12-13-2010 11:22 PM
wish i would of thought of that before putting two giant dents in my doors trying to body check them open
Ttop191 12-13-2010 11:25 PM
I love doing that...gives the car character :lol:
cavaliers60 12-13-2010 11:28 PM
My mom's car does that, I get to be the lucky one to pull them open for her when it happens. My Alero does it too sometimes, but not all the time (thank goodness).
heineck 12-13-2010 11:28 PM
hahaha
AleroB888 12-14-2010 12:12 AM
This is funny, my mom's Lincoln is doing that, too. But today the door would not latch or stay closed when I tried to close it after getting in the car, so I had to sit there for 10 minutes till the lock and latch functioned. :(
Redog 12-14-2010 02:26 AM
Happened to every car I've ever had. Including the "X's" Altima about 2 hours after saying to me "Japanese car doors don't freeze" :rolleyes2:
:wtf2:
Same thing happened to my Parents Relaint back in the day. Of course it was may fault somehow. Door lock was frozen open
cherrington17 12-14-2010 08:54 AM
I usually hit the seal around the edges with a few quick pounds. (never dented it) and break up the ice.
opens just fine after that. But... I did put dielectric grease on it about 2 years ago to help seal better. (wasn't for the ice reason)
That01Olds 12-14-2010 09:40 AM
My car does it to. The Alero did it several times last winter and I went to open the doors on my Intrigue last night and the doors were frozen, but I still managed to get it open.
kwhauck 12-14-2010 10:39 AM
I always go to the passenger door, just in case my hulk like grip rips the handle off......
Fenderxcore 12-14-2010 08:16 PM
Not gonna lie, I've had to enter through the trunk a time or two
robalero 12-14-2010 08:47 PM
use silicone lubed on the rubbers of the door it will cure this issue
pharmerphil 12-15-2010 08:19 AM
My doors freeze to...off to give em' some lube..another question answered here that helps!! Good Job folks!! :)
zzyzzx 01-05-2022 07:55 PM
Having this trouble now too. Going to try silicone spray or dielectric grease one one of the doors first to see if that makes a difference.
LRM88 01-11-2022 10:09 AM
I have used silicone spray which helps, but doesn’t solve the problem. The heavier dielectric grease may be a better choice to try first.
zzyzzx 01-24-2022 07:50 PM
Originally Posted by LRM88 (Post 667584)
I have used silicone spray which helps, but doesn?t solve the problem. The heavier dielectric grease may be a better choice to try first.
I will try dielectric grease on one door, and silicone spray on another and report back.
zzyzzx 02-09-2022 06:11 PM
Silicone spray did not help one bit.
jawa 02-19-2022 03:48 PM
if you move south they wont freeze any more
