-   Audio, Video & Security (http://www.aleromod.com/forums/forumdisplay.php?f=16)
-   -   How Do I Remove The Board... (http://www.aleromod.com/forums/showthread.php?t=3348)
shockz 08-15-2004 03:52 PM
I'm working on stoping the vibration that is coming from my back board (the one that meets the rear window and holds the rear speakers in)... but I need to know how to get it off.
Is their some sort of screw in the trunk... or clamps??? How do I get it off..
Thanks,
AleroGL02
FormulaNERD 08-15-2004 04:12 PM
1. remove the seat backs in the rear (there is a release on the hinge between the 60/40 split
2. remove the side panels where the seat belts are
3. remove plasitc piece where seat latches are (held in by 4 plastic fasteners)
and you should be able to remove the rear deck, but might have to remove the plastic trim around the rear side windows
bnight04 08-15-2004 04:12 PM
i had the same problem, you have to pop off all of the rear panels in the back, like under the windows and across the rear seat. after all of them are off the board should almost just slide out........mine did
bnight04 08-15-2004 04:14 PM
hey formula i have a ?, do u know how to remove the door pannels????
cwm33 08-15-2004 04:15 PM
post what you did to silence the rear deck please, mine makes an ungodly racket on a few songs, and I'd certainly like to know a few methods to get it to shaddup! :thumbsup:
FormulaNERD 08-15-2004 04:19 PM
you mean to access the front speakers? yep.
theres a little reflector at the bottom of the door (so that an car coming could see the door open) well pop that out, there is a screw, remove it.
then at the door handle part where you pull to close from the inside, there is a little cover, pop it off and there are 2 screws, thake them out. go ahead an unplug all the electronics, i belive the rest of the door is held on by the same plastic fasteners as i talked about in the back, just pull around the bottom, then the sides, and the top will slide up and off, the panel hangs near the window entry.
if theres anything else you need to know, let me know
shockz 08-15-2004 04:29 PM
Will do... right now its either dynomat or I can get this free rubber foam stuff from work. I'm going to go the free route first... if it works good I will find out the brand, etc...
- AleroGL02
shockz 08-15-2004 04:32 PM
Thanks so much! :)
FormulaNERD 08-15-2004 04:41 PM
no prob
smokinAMD 08-15-2004 06:45 PM
My entire rear deck is covered in dynamat, as are my doors. Got rid of the crappy water deflectors. No vibratsions. Trunk lid is covered as well.
cwm33 08-15-2004 07:31 PM
did covering the rear deck in dynamat work to silence the beast??
smokinAMD 08-15-2004 07:56 PM
I never noticed any rattles before hand, but it certaintly won't rattle now.
FormulaNERD 08-15-2004 08:46 PM
what 6X9's are you guys using? i'm looking for some with alot of bass, cause i dont want/have the room for woofers... and they need to handle 100RMS, which isnt a whole lot.... any suggestions are welcome.
smokinAMD 08-15-2004 09:12 PM
I have Infinity Kappas all around. The 6x9's sound freaking amazing. Be prepared to spend some time getting those suckers to fit though.
FormulaNERD 08-15-2004 09:24 PM
i'll have to check the power handling specs for those... i have the reference series up front, and some crappy mtx in the back, the fit was easy for those though...
smokinAMD 08-15-2004 09:31 PM
The 3 way 6x9s can handle the power easily. But they are freakin huge. Takes a lot of work to get those suckers in. Definantly worth the effort though.
http://www.crutchfield.com/S-6Ng3UBFe4Kr/c...1&avf=N&search=
shockz 08-22-2004 09:55 PM
The rubber foam worked well... I cut the foam so it would fit nicely and then just put everything back on. No rattles come from the backbaord.
Now I just have to fix my license plate area.
cwm33 09-02-2004 06:09 PM
why did you take out the seats?
I only did steps 2 and 3, and was able to get the rear deck off just fine
FormulaNERD 09-02-2004 10:51 PM
i guess you could, but you wont be able to pull of the part completely explained in #2 ... and it takes 2 seconds for step one. and you wont have to worry about the side panels taking any damage, or being in the way.
turtles_ride 09-03-2004 12:01 AM
i left my seats in when i did my back dash. I pulled the coat hooks off the back panels, then i pulled the panels inward toward the center of the car until the 3 plasticpushpins popped out of their holes. Pull the drivers side rear panel forward a bit and you can slide the backdash free and out. I hated taking out my back seat. The 2 screws in the centre that the seat backs pivot on, what a PITA getting those back in. And even though i knew it was there, i smashed my head on the rear seat clip about 4 frickin times man, drew blood twice SOB. Ya, so AVOID TAKING OUT BACK SEAT AT ALL COSTS BATMAN, IMO.heres a pic, i decided to recover my deck when i had it out, i have my seat pulldowns running inside my car so i can reach back and pull down my seats
