Another black 2-door
After 8 years i crashed my 01 2.4 Grand Am
![]() ![]() Then i came across this 01 fully loaded minus the sunroof. I'm slowing putting all my grand am stuff on it. I had it for almost a year. When it cools down I will do the headlight mod where both run on high. ![]() ![]() ![]() The coils went out so i throw on some junk yard coils ![]() |
nice car i am assuming from the video it is a 5 speed. welcome to the site.
Welcome, rocketfast!
I know you from Gagt. Will is the name, right? |
Yep 5-speed
![]() And B888 it's will. rocketfast123 on gagt, long story when i join back in the day. Rocketfast321 on everything else. And sweet you have. The bass of the 3400 + the high of the s/c is tits. |
I'll buff right out!!! |
lets not be silly its obviously gonna need a wet sand to |
Welcome to the site from the Volunteer state and nice looking Alero too.
Nice to see another 5 speed. Btw JWL you can also tell its a 5speed by the clutch reservoir in the engine bay pic(right next to brake fluid and fuses).
And dont worry theres few of us here that can waxed that camaro too lol.. what you ran anywayz? |
oh thanks. |
16.8. |
A friend of mine (bodyshop) look over my car, and just like i thought. It has been crash before. Only took him like 5 seconds. Where the fender bolts up on the driver side, the bolt area is crush. And their is a gap under the headlight on the driver side. So that's the reason the driver side had a new tie rod end. But i still have 2 new one i was gonna put on my grand am. But it rides great no weird tire ware either. I just got to get my wheels balanced. It starts to go wonky at around 80.
Just for kicks my old grand am. I still miss it. I running my friend who had a stock 90 civic :lol: Now you hear them on the side trying to throw me off. And my cb is going back in. |
That sucks that it was in a car crash.
Just a lame update.
2 front hubs 2200 OHV coil pack swap (i did not feel like spending $140 so $25 at pull-a-part, 2200 plug wires. "$17 life replacement." And i just rebuilt the 2.4 ignition system) New Plugs Ac-delco 41-what-ever Summit rotors slotted and drilled all the way around. Autozone duralast gold pads. They don't throw any dust. Royal Purple ATF in the 5-speed at 125k. Doesn't rattle as much New idler pulley on the belt tensioner. I did not feel like replacing the whole thing. New belt and both rad hoses. Belt was bad, so i did the hoses. Put dex cool back in. Oil changes always been with 5-30 synthetic oil or simi-synthetic oil, with an oversize filter.(aka northstar 4.6 filter) She burns oil at the 50% mark. But it always a Qt. I just top it off with dyno 10-30. What ever the rubber spray paint was. (I'm drunk right now) It made it pass summer and that paint it still good on my ebay WAI, and my Quad 4 High Output ICM cover. I am very happy with my car at 132k. Other than the abs, low trac, svs light on. I will recheck the connections. The 2.4 pulls hard a/c still works. The leather sucks. The flasher relay is wonky, but a quick hit makes it works. Now it drop to like 70 my blower relay is going out again, but it only happed once But both my windows are right now doing the the motor lock up. But I use the trick i learn from the grand am {i made this video] So here is a lame video of Micky. E-brake still doesn't work, so i have to put a 1 liter bottle under the e-bake to hold it up. Last HOON video i made of Micky |
