-   -   ????traction control system???? (http://www.aleromod.com/forums/showthread.php?t=34532)
Papa Rad17 07-29-2011 12:25 AM
I have made an interesting discovery... I think. I have an 03 2.2 gl1 it does not have the traction control system, does have abs front brakes (standard right?) and will putting on disk brakes in the rear next week and plugging in the abs sensor to those as well. (the only reason I mention this is because I dont know if it makes a difference of not) I had my shifter area cover off earlier running a new power wire to my toggle switch where the trac control button would normally be... but while i was in there i noticed a plug, not plugged into anything, I called my buddy over who has on 02 gl2 3400. and popped his cover off, the plug that was chillin in my car is the same one that plugs into the trac control on off switch! :eek: :eek: :eek: ???????? O.O so.. what the hell!!!!!!!!!!! if i get a switch and plug it in will I have the traction control system or is that just a standard deal they did for all aleros and just didnt put the extra stuff in ones that weren't going to have it? im really confused by this... help please.
Cliff8928 07-29-2011 02:09 AM
You either have 4 wheel abs or no abs. The traction control is included with the ABS.
a.graham52 07-29-2011 07:03 AM
id say you have it. plug a switch into and see hwat happens.
pawzbear 07-29-2011 07:23 AM
Yeh I thought it was standard? My 99 GL had the trac switch and abs. Do what he ^^ said and see...
Shiwnath 07-29-2011 09:11 AM
I believe in the later years it was no longer standard. It was optional. i know for sure my girlfriend's 04 Alero doesnt have ABS or ETS. Its funny because on her shifter bezel you can clearly see the outline where th ETS buttom should be.
brheller 07-29-2011 11:56 AM
03 here, base model, no abs or trac. It was an option on the later years.
Papa Rad17 07-29-2011 01:22 PM
Im going to borrow his switch sometime and see what happens, if it works I'll just grab one from the junk yard... I'm guessing that would be a pricy part new. Do I need to go ahead and get the rear brake conversion done before I plug in the eta switch?... And I'm pretty sure I have the abs system, it said so on the brake pedal...
