Missfires in la 3400
just changed my sparkplugs in my 04 alero all torqued to the spec of 132 in lbs i put e3's in so i dnt go cheap with a $1 plug cant figure it out is it the wires dnt know if they have ever been changed look ok ac delco brand I did them one at a time so could not have mixed wires and i pulled them and check all were fine no cracks in them Help
You had misfires before the plugs were changed or this started after?
over time most people have found that they cause problems...the easiest way to make sure that it is the plugs and get a refund would to be to figure out which cylinder is misfiring and move that plug to a different cylinder...if the misfire moves then get something else
iv never been a fan of those plugs. get some ac delcos! but yeah. if you had a missfire before doign the work i suggest waht everyone else as said. find out where its missfiring first. if it was missfiring after then check the work you have done. make sure the wires are right, make sure the plugs all look ok etc.
ok it was after the plug change... now i went back to advance got the Ac delco plugs that are recommended and i changed the wires as well im still getting the p300 code but now it dose seam to have the power back and it isnt flashing at me anymore when i accelerate
so if it didnt missfire before but it does not then it has to be something you have done. make sure all connections of the plug wires are right. make sure you get the "click" when you push them on. make sure you didnt knock off a vacuum lines. did you damage a plug putting one in? (it happens. i chased a missfire rough running engine in my 85 c1500 all the way to a carburetor because i accidently smacked the #1 plug into the steering shaft and flattened the electrode" hate to say it but just pull it all appart. inspect EVERYTHING. and try again.
whats the chance its a coil pack
its possible. HOWEVER if your car did NOT have a missfire prior to plugs, but it does now... i would tripple check your shit. hate to spend money (like i did with a $400 dollar carb for a $2.50 mistake)on something you dont need. see if you can get your hands on a scantool. or know somone that has one that can show you exactly what cylinders missing (missfire data) that will aid in your diagnosis if nothing turns up after checking your work.
got it pulled the battery off then checked it all let it sit plug the batt in code was gone took it out she prrred for day thanks |
i heard e3's arent good plugs to run in our cars.
I can't imagine E3's being good to run in ANY engine. That ginormous electrode is good for nothing but blocking the flamefront. Let me demonstrate...if this guy had an E3 fan: :splatter: ...he wouldn't get covered in poo!
I've had NO LUCK with anything BUT ACDelcos in the Alero.
I had the Bosch +4's Caused missing after about 2 years, put in Delcos and it ran great, until one plug popped out, stripping the head. After a "sleeve" type thing installed, my mech put in 4 Delcos and 2 Motorcraft of the same type. Well starting giving me problems again, so I swapped out for 6 ACDelcos after the #3 popped out again. New heads in now, so hopfully that probelm is gone. The plugs had nothing to do with the plugs popping out |
yeah screw those E3's garbage Delcos are working great ...fell for the damn advertising
i did to a while bk
In anything GM the only route is to go woth AC delco Plugs. Sounds to me that you might have bumped something or inadvertantly(sp) unplugged something. Take your time and go over it with a fine tooth comb. You might find it
My alero gave Miss fire codes when the cat converter fully pluged up and had to be replaced.
Are AC Delco plugs not produced anymore?
because around here they are harder to find most garage wont have them in stock... The reason is , is that NGK makes AC Delco plugs now so they don't bother keeping AC Delco plugs which are already on the way to be all phase out/replace by NGK ... or something like that? Anyhow i bought NGK & they work great |
