-   -   bonneville sle wheels? (http://www.aleromod.com/forums/showthread.php?t=37585)
03gxeco 11-27-2013 05:27 PM
i found a set of 17x8 bonneville wheels that look similar to the gagt rims, will i need spacers? I am hoping this will fill out my wheel well a little better.
fisdad 11-27-2013 08:25 PM
Should be fine if bolt pattern is 5x115 or 5x114.3. Google stock wheel former and find a website that tells you but I think they work. Just to lazy to look atm
03gxeco 11-28-2013 08:25 PM
Same bolt pattern and offset as stock wheels. But they are two inches wider. I just want to know if I'll need spacers so they don't rub
Nas Escobar 12-03-2013 07:36 AM
You should be able to go to 17x8 with no rubbing, but you MAY have to get a low profile tire, or the narrowest tire that you can mount on a 17x8. Check tire rack and see if they have any info... they're usually good with that data.
