-   -   Odd issue with fog lights (http://www.aleromod.com/forums/showthread.php?t=38166)
mfuller 09-30-2014 09:38 PM
I am experiencing a strange issue with my factory fog lights - which are 100% stock by the way.
Every so often they will flicker off and on for just a split second. It doesn't seem to coincide with bumps in the road or anything like that.
Where should I start looking? The switch? A bad relay? Or somewhere in the wiring harness?
The headlights are not affected in any way.
sleepyalero 09-30-2014 10:13 PM
Id check relay or fuses.
tw0123 09-30-2014 10:24 PM
I'd check the switch itself for a loose connection that could be causing the interruption.... or the bulb itself could be shorting out in the filament....
mfuller 09-30-2014 10:49 PM
Bulbs are both brand-new. And when they flicker, both bulbs flicker simultaneously. It would be very unlikely that both bulb filaments are shorting out.
guiguilandry 10-01-2014 09:51 AM
to me it sounds like a loose ground somewhere.....
Alerojester 10-02-2014 10:15 AM
Ok along the fog light topic here.. Mine work well but one is so hazed over that its like its not there, is there anything that can be used to clean all the crap off of it?? And I'm gonna agree it could be a loose ground or even a minor break in a wire somewhere
