-   -   Part II: tank drain re: very perplexed on this one (http://www.aleromod.com/forums/showthread.php?t=38688)
jalero 05-01-2016 12:43 PM
OK, I'm ready to replace the fuel pump motor.
Been trying to come up with a method to drain the 7/8th full tank.
I thought I had a solution twice, but further thinking, they were not feasible.
My latest is since I can get the pump running: (although it has started the past three days) to disconnect the outgoing / feed line and pipe to my collection container.
My question is, since the pre-pressure with the key in the 'on' position will never reach it's designed pressure, will the pump continue pumping or is there a 'timeout' of some sort ?
Any additional ideas on draining tank much appreciated.
thanks, jack
sleepyalero 05-01-2016 03:21 PM
Your best bet is to drop the tank, then just pour the gas into gas cans once you slide it out from under the car.
Redog 05-02-2016 01:19 PM
^^ What he said
AleroB888 05-02-2016 02:26 PM
I have drained the tank on my '99 using an Autozone off-the-shelf electric pump and plastic tubing. It's a little costly, and a hassle to get the tubing in and back out again, but I've done it.
falloutboy 05-02-2016 03:22 PM
First: yes the pump will shot off after a few seconds.
Second: u could just short the relay for the fuel pump and let it pump it out
Third: just unplugging the lines and let it drain will MAYBE be enough
Fourth: if u have a second pair of hands, drop the tank with the fuel in it - but be prepared that this MAY be a mess.
jalero 05-02-2016 05:35 PM
Thanks Guys
I'm going to start with the relay jumper and if that is too slow,
will pump from disconnected fill-pipe as well.
again, thanks for ALL.
jack
falloutboy 05-03-2016 01:30 AM
make sure to unplug the filter before u do, and let it drain from before the filter. This way u dont have to pump all the way, and against the restrictions of the filter
The filter u later on change anyhow ;)
paul ron 06-18-2016 10:52 PM
Why cant you just siphon it out?
I used a bulb siphon to start my flow, then remove the bulb once its going. Took 20 minutes to empty my tank.
