-   -   Trunk Won't Release (http://www.aleromod.com/forums/showthread.php?t=5392)
mgreen808 01-26-2005 03:33 PM
My trunk won't open unless i use the key for it...that sucks :pissed: anyone know how to fix this problem? it's not the switch, because i can hear the relay when i press the trunk button.
kwhauck 01-26-2005 03:57 PM
your trunk safety lock switch is probably on.........
Sundayalero 01-26-2005 04:36 PM
Right. When you open the trunkm, look underneath where the latch is. There is a red switch.
jackal2000 01-26-2005 05:26 PM
did you guys not read his whole post? he said its not the switch. i know sometimes my trunk gets stuck cause the weather stripping but thats after it pops.
MikeSS 01-26-2005 05:30 PM
Get rear-ended by a mail truck....that will open the trunk right up! :D
NOTE - trunk may never close again.
Nik1128 01-26-2005 05:46 PM
The switch only works when the car is locked (and then only the key FOB will open the trunk). If the car isn't locked then the trunk release button inside the car works.
Sundayalero 01-26-2005 06:30 PM
Hmmm, I thought he meant it is not a bad relay switch. I know that when I have my lock-out switch on lock, and I push the open button, I hear the noise he describes..... Hmmmph. <_<
kwhauck 01-26-2005 06:32 PM
yes i read his whole post, i am assuming he is referring to either a keyless fob "switch" or the button "switch" on the door panel................he can hear the trunk try to open when he pushed either of these "switches" but it doesn't open............in that case the trunk lock "switch" is in the locked postion........
either way his using the word switch has made this situation somewhat confusing.......:wacko:
jackal2000 01-26-2005 06:33 PM
agreed. looks like we need some clarification.
Sundayalero 01-26-2005 06:39 PM
Yeah, where did he go?
ImSoBored 01-26-2005 08:09 PM
with the lock out turned on, itll still make the release noise. Chances are the lock out switch is in the lock position
Youngblood77 01-26-2005 10:10 PM
If he "hears" something working, it sounds as though the selenoid is working, or at least trying. The trunk safety latch may be keeping the trunk from opening, but another possability is the selenoid may not be moving far enough to effectively "un-hook" the latch due to the cold climate and/or lack of lubrication.
I'd do 2 things: a) make sure the safety latch is allowing said action to take place, and
B) Spray some white lithium grease ( found @ any auto parts store, it's also good foor door & trunk hinges that squeak ) on the exposed part of the selenoid plunger, then activate it over and over drawing the lubricant into the cylinder. This will ensure that it STAYS working, too. :thumbsup:
Hope this helps. :)
AGT 01-26-2005 10:18 PM
Could be the flux capacitor :D
mgreen808 01-27-2005 01:28 AM
ok, just for clarification, when i hit the button on the door, i can hear the relay on the inside...nothing from he trunk. when i hit the fob when the trunk is open, nothing happens...it should click the solenoid, right? And where exactly should the red button be? someone's been playin with it i think
ImSoBored 01-27-2005 10:26 AM
its right by your latch on the lid. Says something like lock out on-off
it should be on off, if you want the button/fob to open it
Mystickal 06-22-2005 12:51 AM
Thank you. My trunk release stopped working 3 days ago - I could hear the solenoid click, both when I pressed the FOB and when I pressed the button on the driver's door, but the trunk stayed closed, opening only with the key. I looked at the release, and the solenoid seemed to be operating fine, I couldn't figure out what was wrong - didn't see the "lock" switch on the other side of the latch - fixed the problem real easy.
Much better than spending $50 at the dealer. Thanks again.
~Bill
pawzbear 06-22-2005 12:55 AM
yep, that was my diagnosis
speedbug 07-29-2005 12:19 AM
Thanks for asking this question!! :biggrin: I'm new here and I've had this problem as well, and I never saw the red switch :blink: saved me some cash as well!!! :beerchug:
daferns 09-05-2005 12:54 PM
hey everyone i seem to have a rather big problem, my trunk isnt opening with remote or button on the inside, can anyone offer suggestions? i cant get into my trunk!!
Oldsmopimp 09-05-2005 12:58 PM
sure! ...Use the key. :)
