i've heard that lowering your car does make the ride quality a little worse, meaning you feel more bumps, and "feel" the road better.
...but handling is better. what would you use to make you "feel" the road less? what kind of mods?? this is just for fyi kinda info, personally i still want to lower my car... :lol: |
air ride.
like the setups some of the guys on here have? doesn't that cost a few thou?
contact forbidden, or check the air ride thread.
~2100$ |
when u drop your car, using spring, or coilover, the ride is stiffer and actually that helps your vechile but you will feel more bounce. Air ride helps dampen some of the bounce but it still not gonna be like stock.
Contact forbidden, silent, or pimp |
Rsm sells B&G springs which lower bout the same as eibachs but the ride is not far off stock. They stiffen up nicely just not as stiff as eibachs. These are the ultimate if you are looking for a 1.5 inch lower but not sacrifice ride quality. You will not be unhappy.
10psi in your tires
Extremely grippy tires ya got there :lol: :lol: :lol: |
even when you let out some pressure? |
nope. it would help out but its still not like riding in a bagged truck. i was kinda shocked when i got my aleor back and it didnt ride like i thought. when i hooked up with a local grand am with bags i took a ride in his car and it was like mine. but u get used to it.
its because you have smaller profile tires... if you was to put your stock tires you would feel a difference
so there really isn't anything that makes the car ride better? or is it just not feasible? i've rode in a benz and a nicer buick and it was like you didn't even know you were in a moving vehicle... what are they using for that?
taller tires, like switching from a 16 to a 15 would help some. dont get kyb's, get monroe sensatrac's. we can handle "pretty good" with a pretty crappy ride. |
i put my stockers back on before i stored my car, still had a bumpy ride. a lot better then the coilovers i tried though. lol
well, at least that cleared up some mis-conceptions about air-rides... :lol:
