-   -   Window Problem (http://www.aleromod.com/forums/showthread.php?t=5798)
Super White Alero 02-24-2005 12:59 AM
Ok, my window has a problem. There are 2 plastic peices that are joined to the window that bolt directly to the x-member that move the window up and down. The rear white piece that join the bolt to the x-member is broken. Any idea where I can purchase just the white piece, Gm doesn't sell that without the glass, and the junkyard refuse to sell me just the plastic piece.
And I should mention I have no friggin clue where the bottom half of the plastic is so I can't glue it togather. Please help this suck when I have to use both hands to roll up the window.
bigd6983 02-24-2005 10:36 AM
you shoulda searched, their are tons of posts on here.......especially from me.......you are going to have to buy the whole regulator assembly the motor included.......ive only seen the lil white pieces on ebay ONCE and that was it, you cant find them anywhere else......i got my regulator for 60 bucks shipped off of ebay and it works fine, now i got 2 motors incase each side wants to go bad.......
NATIVE 02-24-2005 10:52 AM
same thing happened to mine had to buy the whole new regulator
from a 03 alero salvaged.
Super White Alero 02-24-2005 11:37 AM
R you talking about the same piece I m? The piece im refering to is the piece that is epoxy glued to the glass not the piece that attached to the x-member.
rowdygls 02-24-2005 01:09 PM
what side do you need, i may have a spare from when my window got fixed. my dealer just ordered the white pieces. i could talk to them and see if they can order me just a set and i could send them over to ya.
j-work 02-24-2005 01:17 PM
rowdygls are you sure your dealer just ordered yuou the plastic clips???
rowdygls 02-24-2005 03:16 PM
yep, i believe i have a spare sitting in my glove box. every where they looked said they didnt have the clips, like they were discountinued or something. sent an order direct to gm and told them my car was undriveable without them, about a week later the parts were in.
Super White Alero 02-24-2005 07:49 PM
I have a 2 door and the piece I need is attached to the rear of the glass on the driver side, that is the piece that broke off. if you got spare pm me thanks rowdygls.
rowdygls 02-26-2005 11:41 PM
hey white if possible can you get a pic of the piece. I do have a clip,
part #22697622. I have no idea which side or if they are universal. I tried GMpartsdirect.com and they were no help as to what side. so like I said if possible post a pic of so i can compare mine to yours.
bluephoAm 03-01-2005 10:52 AM
Epoxy it back on.
rowdygls 03-01-2005 12:36 PM
it not that easy of epoxying it back on, the plastic itself actually breaks so unless you epoxy the plastic piece or something and it holds youre still in the same boat as before.
