-   LA1 3400 Specific (http://www.aleromod.com/forums/forumdisplay.php?f=19)
-   -   Just A Thought For Wai...... (http://www.aleromod.com/forums/showthread.php?t=6840)
sud1616 04-28-2005 11:01 PM
Has anyone ever left the down tube from the stock air box and modified it so that fresh cool air would be directed to a wai? Just a concept I thought about after some looking under the hood.
SSmite Thee Human 04-28-2005 11:11 PM
I wouldn't be too keen on modifying the (surely very expensive) stock assembly, in case I ever wanted to go back to the stock setup (to sell the car or whatever). I doubt if the stock box is big enough to be of much use anyway.
Incidentally, I'd wager that more cool air gets through the hole without the pretzel of a stock setup in the way.
sud1616 04-28-2005 11:16 PM
It wasn't thebox Iwas worriedabout. I was thinking about removing thebox and modifing the down tube todirect coolair to a WAI. It seems the down fault of a WAI isthe hot air in the engine bay. I just thought if cool air could be directed right at the filter on a WAI from maybe behind the fog lights it would help. Like I said.....just a thought.
99Olds 04-29-2005 09:04 AM
I think I see where you are going with that. Its a good idea. But I dont know how ull do it?
Naich 04-29-2005 10:01 AM
It has been done by someone who I don't think posts here any more. The problem is that the theory works... but in reality it doesn't really do much. The thing is, you would think that the cold air from outside would just climb up the stock intake tubing and flow into the engine compartment because of the speed you are going. However, it really doesn't flow up much by itself.... it needs the engine to suck in the air. Also, in reality, more air comes into the engine compartment through the front air dam and the underside of the engine than would come in through the stock intake tubing.
If you could work it to put a tube out the front of the car, and run it through to the filter, that would force air into the engine bay, but it would also look ghetto as all hell.
jackal2000 04-29-2005 12:21 PM
why not just get a cai??
Naich 04-29-2005 12:42 PM
I can think of 2 reasons....
1. If you leave the bottom portion of the stock intake (the piping and stuff), you could probably re-attach the stock box pretty easily if you had to bring it in for warranty repairs & stuff like that.
2. If you are really concerned about sucking up water into the intake with the filter mounted in the fender... this would help you not suck up water.
-Alero- 04-29-2005 01:16 PM
ive done it, except i replaced the plastic part with some aluminum piping, i got , and its shaped liek a wierd S, and it comes out next to my driver side fog light. it doesnt really do much but, push up alot of small rocks and dirt in the engine bay....
sud1616 04-29-2005 09:14 PM
Well, like I said, it was only a thought. Figured if anybody would know you guys would. Thanks for the replys.
