Old 04-01-2005, 01:45 PM   #41
snake_eyes2
have you been able to fix this problem yet? I even had to go and pull my HU out and rewire into the ant, it was pissing me off Anyway if you still need held send the wiring diagram / colour code for your deck and I will look into the answer for you.
Old 04-01-2005, 02:53 PM   #42
Chucklez05
Talking
My reception sucked, I got 1 FM station and no AM stations. After I hooked up the wire i get every station in the area and some from pretty far away
Old 04-01-2005, 05:47 PM   #43
slowandlow
slowandlow's Avatar
i am thinking of getting a aftermarket hideaway antena that has a higher gain than stock so i get better and from longer away
Old 06-21-2005, 06:41 PM   #44
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
Found this THREAD via the SEARCH feature, had same problem, new PIONEER CD head unit, no AM reception. I took it for granted that those blue wires were for power "motorized" antenna, so I left them disconnected. Took radio out again connected wires, problem solved.
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 07-23-2005, 07:15 PM   #45
switch
Hmm..Im using the GM Data Class II harness. and I have no "Power Antenna" wire. I do howver have an Amp turn on. Should I hook those two up?
EDIT - I went ahead and connected them It works great now. Im just an idiot.
Old 09-12-2005, 10:20 PM   #46
marcsalero
dude you are my hero I get every station and like ten I didn't know about thanks
