08-22-2005, 09:18 AM
sunday i was going to paint my calipers in the front i got one rim off the other one i could not... four lugs came off with ease the fifth did not it turned a few times then it stopped, it got harder the more i turned it to take off :wtf: any suggestions or ideas of what i should do???? im p-ed off.  issed:
08-22-2005, 09:22 AM
Keepin it Real
sounds like that lug was cross threaded, sorry about your luck and good luck getting it off. try using a breaker bar, you will probably snap the lug but thats the only way to get the wheel off. then you will of course have to replace the lug. if using air tools ALWAYS hand screw the lug onto the threads first.
2015 Audi SQ5
08-22-2005, 09:55 AM
be careful though, you might snap the bolt for the lug. Try to tighten it again and take it off, it its cross threadin again.... good luck
2004 40th aniv. mustang
2006 kawasaki ninja
08-22-2005, 10:11 AM
Keepin it Real
depends how it looks, chances are that it will need replaced
2015 Audi SQ5
08-22-2005, 10:23 AM
If it's cross threaded you mine as well just get a breaker bar and put some torque on the lugnut and break it off. If you've already been fighting with it odds are the stud is screwed up and it's going to need replacing anyways. The studs aren't that hard to replace.
08-22-2005, 11:43 AM
werd. or if ya got a good impact gun i know that'll break it off too.
08-22-2005, 12:06 PM
[quote=jamcllw,Aug 22 2005, 08:23 AM]
where can i find replacement studs? if need be
08-22-2005, 12:11 PM
just about any good parts store would have them
08-22-2005, 12:12 PM
are the costly, and hard to do yourself.
08-22-2005, 12:19 PM
Probably about $1.50-$2.00 each. New lug nut is about $.50 each. As far as difficulty. I'm not sure about Aleros but I've done tons of them on other cars and they were all cake. You basically beat the old one out and then beat the new one in.
08-22-2005, 12:24 PM
parts store can tell you
08-22-2005, 12:27 PM
thanks.......  guy you have been a big help.
