Old 04-04-2006, 01:04 PM   #61
dbailey
dbailey is an unknown quantity at this point
As much as it may seem to the the caliper pins, it is not. It is the piston in the caliper that causes this problem. As I said previously in the thread, I bought the TSB required lube and squirted it around the piston at least a year ago and have not had the problem since. It is way too easy to do.
dbailey is offline   Reply With Quote
Old 05-25-2007, 04:16 PM   #62
AsianAlero
AsianAlero is on a distinguished road
Send a message via AIM to AsianAlero
Sorry to bring up this old post. But uhhh could I just apply some lithium grease to the piston?
AsianAlero is offline   Reply With Quote
Old 05-25-2007, 04:25 PM   #63
jackal2000
Keepin it Real
jackal2000's Avatar
try it out and post the results, i dont see why it wouldnt work. it might not work for a long time though.....
2015 Audi SQ5
Old 05-26-2007, 08:12 AM   #64
Vinalero
Vinalero's Avatar
Im more than happy he brought back this tread, when I saw it I heard that little tone in my head (you know the one that played in Zelda 1 on the NES when you found an item : Duh dududu!)
My brakes just started doing that, thought it was the calipers, thx god I know that know
Old 05-26-2007, 09:41 AM   #65
antichrysler
personally i think with something like brakes you don't wanna mess around with em... whatever it needs done get it done and be safe
