Old 04-28-2006, 05:36 PM   #1
number1alero
number1alero is an unknown quantity at this point
So yesterday my Service Vehicle Soon light comes on, and then last night i noticed that my gauges were not lit up, and the auto/parking/manual light controls were unresponsive at night time....perhaps its a blown fuse or something else? i checked the bulbs and they seem to be fine, except i havent had a chance to check the parking lamps yet. any help appreciated. thanks
number1alero is offline   Reply With Quote
Old 04-28-2006, 11:52 PM   #2
number1alero
Now that it is dark out...it seems that part of my DRL is the problem...my headlights are on, but the taillights are off, and only come on when i press the brake down....any pointers greatly appreciated...thanks!
Old 04-29-2006, 03:29 PM   #3
2fst4u
[boosted 2.4L]
2fst4u's Avatar
there's a fuse up front under the hood to check out. you may have shorted your dash lights out. were you doing anything in there? or were you just normally driving?
Old 04-29-2006, 04:56 PM   #4
number1alero
ive already tried to replace the micro relays under the hood...it happened under normal driving conditions a couple days ago...no aftermarket wiring or anything
Old 04-29-2006, 06:19 PM   #5
exnine@gmail.com
exnine@gmail.com's Avatar
exnine@gmail.com is an unknown quantity at this point
Send a message via AIM to exnine@gmail.com
Have you noticed any corrosion or white looking substance on any of the fuses? Or rust?
Welcome to my sig.
exnine@gmail.com is offline   Reply With Quote
Old 04-29-2006, 06:28 PM   #6
number1alero
no...actually i went to the junkyard and found a couple fuses that hadnt gotten weathered and were fine, and still didnt help (i changed both the DRL and headlamp microrelays)
Old 04-29-2006, 06:31 PM   #7
number1alero
i also checked the normal headlights and the bright lights, they were fine...but also my fog lights dont work either.
Old 04-30-2006, 10:42 AM   #8
robz02alero
robz02alero's Avatar
robz02alero is an unknown quantity at this point
Send a message via Yahoo to robz02alero
If you can swing a set of wiring schematics, it sounds like a ground to me. You have a serious issue on your hands because if it's a melted wire or something like that a fire could start. Good luck.
owner/operator of : The Pinnacle of Clean Auto Detailing Service www.pinnacleofclean.blogspot.com
Supporter of Aleromod.com
OIF VETERAN X3
COMING HOME SOON
robz02alero is offline   Reply With Quote
Old 05-01-2006, 02:48 PM   #9
number1alero
Well found out I had a blown parking lamp fuse...how the hell that affects the entire DRL system I have no clue...but anyway if anyone ever has trouble with their DRL lights then be sure to check all fuses and relays that have anything to do with lights, not just specific fuses or relays for DRL.
Old 05-01-2006, 03:22 PM   #10
2fst4u
[boosted 2.4L]
2fst4u's Avatar
isn't that what i said? and guess where it is, under the hood.
Old 05-01-2006, 03:46 PM   #11
number1alero
theres about 10 different fuses for lights...so in essence you didnt help much
Old 05-05-2006, 10:27 PM   #12
number1alero
well this problem reared its ugly head about 20 minutes ago...there must be a short or something because i tried a 20 amp fuse and it blew as well, and its only suppose to have a 15 amp fuse.....we shall see what the dealer says tomorrow or monday
