Old 05-06-2007, 04:04 PM   #1
lovefrom1977
lovefrom1977 is on a distinguished road
car broken into and lock popped. need help.
hello, my car was parked outside the mall for 45 minutes and when i came back my backpack containing my laptop, ipod, psp, camera, etc. was stolen. i know i shouldnt of left it on the ground of the passenger side but i did. so now the lock is popped in. does anyone know how much this would cost to get fixed or the difficulty level it would be for me to fix it?
also i tried to roll down that window and i hear a loud almost like cracking noise so i rolled it back up and just left it there. i hope i didnt mess anything up on that?
lovefrom1977 is offline   Reply With Quote
Old 05-06-2007, 04:22 PM   #2
teflone
teflone's Avatar
teflone is an unknown quantity at this point
ouch..
Well, it would cost you about 100 bucks or so at least for a locksmith to fix it..
And rolling the window down is a bad thing..
You most likly bent your locking rod and possibly damaged other components like your window regulator plate..
But hopefully you didnt..
You must take your interior door panelling off and assess the damage..
if you look carefully the rod that should not look in place will have a hole or small bend to accept the hole in the back of the exterior part of the door handle mech.
bent it back as best you can..
this will be all very complicated because you most liekly cant see many of the things im talking about being inside the door..
there will be plastic and padding presumably and you'll have to do all this through holes in the door sheet metal..
take some pics once you get access and I can help you more..
teflone is offline   Reply With Quote
Old 05-06-2007, 04:33 PM   #3
lovefrom1977
alright im not sure when i can take it apart yet but i asked the dealer how much it was to get fixed and it was $420 with parts and labor and $580 with parts including new door handle(if needed) and labor. do i need a new lock or can i just put it back in there sort of?
Old 05-06-2007, 04:45 PM   #4
teflone
teflone's Avatar
Ohhhh..
Your key hole is pushed in as well ?
Then it is most likely ruined..
You'll have to try to see if you can still use the key in it, and the clip that holds the cylinder in place is off probably hopefully intact in the bottom of your door.. its U shaped and made of wire most likly
if your key cylinder is ruined it will be expensive to fix completly
you could potentially if the cylinder is ruined put the cylinder back in place
and disable the lock with super glue (keeping in mind if its ruined it will unlock with a simple flat head screw driver) so diable it and hopefully you got power unlock..
whatever you do.. dont put your window down again untill fixed..
Old 05-06-2007, 05:17 PM   #5
TwistedDreams
VIP
TwistedDreams's Avatar
TwistedDreams is an unknown quantity at this point
Send a message via AIM to TwistedDreams
Well sounds like it sucks, next time dont have the whole circuit city store in your car
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
TwistedDreams is offline   Reply With Quote
Old 05-06-2007, 08:17 PM   #6
sofa
sofa's Avatar
sofa is an unknown quantity at this point
Send a message via MSN to sofa
same thing hpeened to me if all parts are there most likely the plastic clips holding the cylinder are just broken. i just re assembled the cylinder to the handle and the rod to the handle then used construction adhesive to hold the cylinder in place..it worked pretty awsome..but then again i dont use my key to open the door anyways..pull ur door panel off and look to see what the damage is like those prices for fixing it are redic.
Straight.From.Steel.City
http://www.cardomain.com/ride/2313940 http://www.myspace.com/kowch
sofa is offline   Reply With Quote
Old 05-06-2007, 08:18 PM   #7
well atleast he didnt have a plasma tv in there
Old 05-06-2007, 09:46 PM   #8
antichrysler
I'd be pissed... same thing happened with my cavalier... ended up getting a whole new door and they replaced a bunch of random stuff (didn't care since insurance paid for it)
Old 05-06-2007, 11:26 PM   #9
lovefrom1977
it is the passenger door so i dont need to use the key on it ever and i have power locks, so can i just basically put it back and then use an adhesive to hold it on? or what else?
Old 05-07-2007, 01:01 PM   #10
jturkey69
jturkey69's Avatar
jturkey69 is an unknown quantity at this point
Send a message via Yahoo to jturkey69
will ins. cover all the stolen goods?? sorry to hear bout the theft
OCA Alero Chapter Member!!!!
ALERO-LESS
1971 Olds Cutlass budget pro-touring project
2005 Nissan Altima SE-R 6spd MODDED! (wifes pocket rocket)
1998 Ford Explorer AWD 5.0...modded, and fun DD
jturkey69 is offline   Reply With Quote
Old 05-07-2007, 01:18 PM   #11
TwistedDreams
VIP
he was probrably rolling one out of the mall when he found out his car had been broken into...
Old 05-07-2007, 02:54 PM   #12
lovefrom1977
Insurance probally only give me a little money but nothing compared to how much it would be to buy the new stuff. there is also a $500 deductible. and i had that stuff with me because i wasn't going to be home over the weekend.
Old 05-08-2007, 03:18 PM   #13
lovefrom1977
does anyone else know how to fix it or have any other advice?
