Old 05-31-2007, 08:51 PM   #1
LiquidXtassy
Smile Car shaking at Idle
let me just start off by thanking all the guys that have helped me with previous problems...lol i feel like i write something on this forum every couple of month...
ok here is another problem
the car start of very nice...once reaching operating temperature which is the middle or a little bit above the middle cause the aleros like it like that.
i feel a vibration though the steering wheel and the shifter..this happens only at idle while stoped at a red light or stop sign..while its moving it rides like a charm..the idle needle moves in small incriments so i cant realy say its a rough idle..i have changed the plugs and wires with some realy good oness...i cleaned out the throtle body and the MAF sensor.
my next step is going to be changing the transmision fluid and getting a new O2 sensor...before i do any of that i was just wondering if u guys have any idea of what it can be causing that. some one told me it can be a EGR sensor.
it has 75000 miles and its a 2001 3.4 alero
Old 05-31-2007, 09:14 PM   #2
DOHC_tuner
DOHC_tuner's Avatar
I think just about everybody has that problem here so if you get a good answer let me know cause I have the same problem, I put it in neutral at the redlight so it can stop shaking, but I think it does have something to do with the tranny, torque converter, or maybe even the balance shafts. But honestly Im unsure. Sorry cant help
Old 05-31-2007, 09:30 PM   #3
Could be a broken vacuum line
Old 05-31-2007, 11:27 PM   #4
LiquidXtassy
if every one has the same problem some one must have fixed the problem some how...as for a vacum leak i checked for that already no vissible signs or hissing noises. also checked codes and nothing pops up....this thread should become a sticky or something some one gotta have an answer lol...keep the sugestions coming. thank you
Old 06-01-2007, 08:49 AM   #5
Vinalero
Vinalero's Avatar
Could it be some engine mounts issues?
Old 06-01-2007, 09:12 AM   #6
antichrysler
if it runs just fine while it's driving it's probably a very minor issue
i bet you could straighten it out with a new fuel filter or fuel injector cleaner... also if you're in an area that has drastic climate changes some condensation remover for the gas tank wouldn't hurt it... and sometimes it's just gunk built up in the engine... fill it up with a tank of premium and take it for a few hundred miles on the highway
yeah yeah i know that's my solution for everything but i always like to start with the cheap repairs and work my way up
Old 06-01-2007, 10:57 AM   #7
TheMeaningOfLife
TheMeaningOfLife's Avatar
My uncles truck idles rough when its starting to need an oil change. I know it isnt an alero but it might as well be done anyways, wont hurt anything.
Old 06-01-2007, 11:43 AM   #8
you said that you changed your plugs and wires, did you make sure you connected them correctly?
Old 06-01-2007, 04:27 PM   #9
comanche
comanche is an unknown quantity at this point
I've had only one 2.4 (quad) out of 4 or so that did not have this problem - the v6s don't seem to have this problem as much. There must be something in common that is causing the problem for all of us though.
It's a vibration when the car is in drive at a stoplight...
comanche is offline   Reply With Quote
Old 06-01-2007, 04:29 PM   #10
antichrysler
my v6 had that problem... then again my v6 had alot of problems
Old 06-01-2007, 05:15 PM   #11
AGT
AGT's Avatar
Yeah I am thinking firing order out of wack
and possibly the MAF prongs might be bent...I had one prong bent when I reconnected and the thing ran like a beastloud growl and real fast but maintained near 2000 rpm at stops.
Old 06-01-2007, 06:02 PM   #12
Alero 2 Envy
Alero 2 Envy's Avatar
Alero 2 Envy is on a distinguished road
1999 2.4 does the same annoying crap. I started thinking tranny mount since it only does it in forward gears. I can go into Nuetral, Park, and Reverse and it wont shake. As soon as I slip it into any forward gear it shifts a little rougher going into it and then shakes.
I am thinking the tranny mount is the one between the firewall & the engine, can anyone confirm this ?
Alero 2 Envy is offline   Reply With Quote
Old 06-01-2007, 10:07 PM   #13
comanche
There are, I think, at least 3 tranny mounts...
Old 06-01-2007, 11:57 PM   #14
DOHC_tuner
DOHC_tuner's Avatar
Its not the fuel filter cause i changed mine and it still does it.
Old 06-02-2007, 08:26 AM   #15
Alero 2 Envy
Before anyone starts throwing $$$ at there ride to figure it out. This is what I have changed, keep in mind I have not had a CEL come on since I bought my car:
* New AC Delco Double Plat plugs @ .50
* New AC Delco plug boots
* Coil cover
* Ignition module
* IAC
* Rear 02
* Fuel Filter
* Air Filter
* Changed Oil (Of course)
* Sea Foam treatment - Helped gas mileage nicley
I love my Alero and has been good to me but this issue has me wanting to trade the Biatch in.
Old 06-04-2007, 09:06 PM   #16
LiquidXtassy
i did everything now the only thing i didnt do is the EGR valve....i priced it out at almost 200 dollars...couldnt find anything cheaper...before i buy it can some of u tell me what an EGR valve realy does and how it can effect it if its stuck open or dirty...
Old 06-04-2007, 09:23 PM   #17
i still think he probably put the plug in the wrong order and its misfiring
Old 06-04-2007, 09:27 PM   #18
SweetNLow
SweetNLow's Avatar
i agree....... double check that the wires are running to the correct plugs
joelsoundxtreme: u faggot
Old 06-04-2007, 10:10 PM   #19
if the plugs are in the wrong order, wouldn't it be more noticeable than just a little bit of rough idle??? I"m pretty sure the computer would signal a piston misfire....
Old 06-04-2007, 10:57 PM   #20
SweetNLow
SweetNLow's Avatar
good point....... people are starting to use there heads around here!!!!! i love it
