Old 10-06-2007, 12:26 AM   #1
DaRockwilder
DaRockwilder's Avatar
Command Start?
My '03 Alero has keyless entry, but not command start. I was just wondering if its possible to walk into the dealership and buy a plug and play system for upgrading to command start? For example just buying a different module and fobs? I would assume all the wiring is there for the system, just the module needs to be changed. Alot less hassle at the factory and dealerships that way, I would think.
thanks for anything!
Old 10-07-2007, 09:43 PM   #2
Kilroy
Kilroy's Avatar
Not sure of the '03, but my '99 did NOT have the wiring for the remote door unlock module, so I am guessing there is a chance the command start wiring isn't there either. I could be wrong though. If you have a book for your car, find out where the command start module should be, then check to see if youhave the plugs?? Just an idea??
Old 10-07-2007, 09:44 PM   #3
DaRockwilder
I have a Haynes manual for it, but its usless for that kind of stuff.
Anyone know where the module is? I have a feeling it might be part of the BCM or something.
Thanks!
Old 10-07-2007, 11:21 PM   #4
the module is clipped into the rear shelf near the trunk light. Unfortunately there's no remote start from the factory in any GM before '06 If i remember right.
Old 10-07-2007, 11:40 PM   #5
yahh you would have to buy a system for it.... my dad used to install the Bulldog ( i think) remote start systems bc he had a good deal with the company. youd get a new fob and all that shazz as well.
Old 10-07-2007, 11:43 PM   #6
DaRockwilder
Ah. Haha, yeah, I think you're probably right about the no command start till '06. I dunno WTF I was thinking.
Whats the GM reccomended brand to install then?
Old 10-08-2007, 12:07 AM   #7
ares89
ares89's Avatar
ares89 is on a distinguished road
i like the system i had put in.. remote start along with security system.. If you kick the tires to hard the alarm goes off. High bass in the car when using the remote start also sets off the alarm. I forget the brand though..
*GONE* 2001 2.4L Alero Sedan... Cleared Corners and 17" Sportmax rims
*New Daily* 2009 Ford Mustang 4.0L Convertible - Vista Blue with Silver Striping
ares89 is offline   Reply With Quote
Old 10-08-2007, 12:18 AM   #8
just get any aftermarket alarm with a remote start, theyre all the same thing until you start comparing their range.
Old 10-08-2007, 12:21 AM   #9
jabartram
AutoCross Alero
jabartram's Avatar
i run a viper system with remote start.
jabartram is offline   Reply With Quote
Old 10-08-2007, 02:22 AM   #10
You could use something like this if you didn't want a different remote.
