Old 04-26-2008, 12:16 PM   #1
irondiezl3
irondiezl3's Avatar
the tires and rims
why do some aleros have factory lower profile tires and some have the regular typical tire size? is it cuz the lower profile have a 16inch rim and the bigger tires have a 15 inch rim? i have 15 can i put the lower profile on that ud see stock on the aleros?
Old 04-26-2008, 12:21 PM   #2
Vinalero
Vinalero's Avatar
In your question you have your answer.
If you think the lower profile tires are on the 16 inch rims, and that you have 15 inch rims, well if you want to install the lower profile tires that you see on the Aleros on your 15 inch rims, when they are 16 inch rims, they wont fit at all, you still with me?
being a bit more serious, well If you want lower profile tire on 15 inch rim size, first of all, it will look like crap, second, your speedo will be off, third, dont do that.
If you want lower profile tire, you'll have to get some bigger rims, lets say 17 and up.
peace
Old 04-26-2008, 12:29 PM   #3
irondiezl3
irondiezl3's Avatar
lol thats what i thought it was. thanks
Old 04-26-2008, 01:01 PM   #4
Vinalero
Vinalero's Avatar
that site will be your friend:
http://www.miata.net/garage/tirecalc.html
Use that to determine which size of tire to get with different diameter of wheels from the stock wheel ratio (On my car, on the side of the driver's door it says it is 205/65/15)
Old 04-27-2008, 11:00 PM   #5
CharleyO99Alero
CharleyO99Alero's Avatar
CharleyO99Alero is on a distinguished road
My driver's door states P215R60/15 so I guess it's just the difference in the years.
CharleyO99Alero is offline   Reply With Quote
Old 04-27-2008, 11:08 PM   #6
Vinman
Vinman's Avatar
Vinman is on a distinguished road
Send a message via AIM to Vinman Send a message via Yahoo to Vinman
the cars(mine included) w/ the 225/50/16 has a factory upgraded suspension package. that explains the factory low pro's
Vinman is offline   Reply With Quote
Old 04-27-2008, 11:24 PM   #7
Mischief007
Mischief007 is an unknown quantity at this point
Send a message via MSN to Mischief007
If you have the Sport Suspension (RPO code FE3) then you get all the FE3 struts, bushings, etc plus 225/50/16 rim/tire combination. That's what my Alero had.
??,??? km
??,??? miles
Mischief007 is offline   Reply With Quote
Old 04-27-2008, 11:28 PM   #8
Conehead2467
Conehead2467 is on a distinguished road
yep, thats what my 01 gls has.
Conehead2467 is offline   Reply With Quote
Old 04-27-2008, 11:43 PM   #9
Malix
Malix's Avatar
Malix is on a distinguished road
Well,
Outta topic, sorta, but how do you know if you have that "Upgrade" on your car? My rims are the polished 16s, GLS model V6.
http://www.cardomain.com/ride/3091095 Visit!
Malix is offline   Reply With Quote
Old 04-27-2008, 11:57 PM   #10
Conehead2467
if i read correctly, if you have the 16" rims you have that upgraded suspension. correct me if im wrong.
Old 04-28-2008, 03:18 AM   #11
Vinalero
Vinalero's Avatar
I think you are right, I'm mixing my winter tire size with the stock ones
Old 04-28-2008, 06:57 AM   #12
I have the 16" rims and 50 series tires the space between the tire and the spring mount on the strut is minamal 60 might hit but IDK
Old 04-30-2008, 09:55 PM   #13
irondiezl3
irondiezl3's Avatar
so what happens if i put the stock 16s with the lower pro tires they come wit stock then will it look normal or is my car not built to have that size?
Old 04-30-2008, 11:53 PM   #14
Mischief007
It should be fine if you currently have 215/60/15s but your speedo will still be off.
??,??? km
??,??? miles
Old 05-01-2008, 11:39 AM   #15
Okay, So How does the tire Size work? I know the last number is Rim Size. What about the other two?
Old 05-01-2008, 11:49 AM   #16
width, height (mm)
Old 05-01-2008, 12:45 PM   #17
width, height (mm)
not exactly.
The first number is the width. The second number is the aspect ratio. It is NOT a size measurement, but a percentage of the width. For example, a 225/50R16 tire has a 112.5mm sidewall.
Your overall tire height is calculated something like this.
Overall height in mm = 2(width x aspect ratio) + wheel diameter in mm
like this-
Height = 2(225x.50)+406.4
Height = 2(112.5)+406.4
Height = 225+406.4
Height = 631.4mm
or in inches it's 24.86
Old 05-01-2008, 01:44 PM   #18
Mischief007
To add to the master (Cliff), the second number is a percentage. That's how Cliff is getting the 112.5 mm sidewall. Half of 225.
??,??? km
??,??? miles
Old 05-01-2008, 05:33 PM   #19
silverbullet81
silverbullet81 is on a distinguished road
so how much off would the spedo be if you had 15's and then put on the 16's with lower profile tires??
silverbullet81 is offline   Reply With Quote
Old 05-01-2008, 05:43 PM   #20
8-10 mph.
totally random answer.
