Old 05-14-2008, 09:37 PM   #21
Vinalero
Vinalero's Avatar
Originally Posted by Spilner521 View Post
Why, what type of supercharger would be better? ...besides that kind that looks like a snail and is exhaust driven...
Damn right
Well I would have prefered a twin screw, but I still love the fact that the supercharger kit is almost a bolt on.
Old 05-14-2008, 09:48 PM   #22
I could fab up the new TVS system from Eaton if someone wants to buy me the supercharger.. lol. Four lobes, 160 degree twist... nice.
The MP45 is suited well to what most require. I have no doubts one can run in the high 12s with it (well modded engine, nitrous, meth, radials, etc)
Old 05-15-2008, 02:12 PM   #23
Vinalero
Vinalero's Avatar
does the secret cams works with the supercharge?
Old 05-15-2008, 02:34 PM   #24
yes a lot of people run them with the blower, any bigger cams will help out
Old 05-16-2008, 12:00 AM   #25
Spilner521
Boost Guru
Spilner521's Avatar
OK good, I thought you might have been thinking of a centrifugal as better, and I would have to disagree, especially on a 4 cylinder.
And yes, the secret cams would go well with the supercharger.
Old 05-20-2008, 07:48 PM   #26
spyhunter
spyhunter's Avatar
anybody running the GM S/C kit will not get 12's.........
ya'll bitchin about gas prices... at least you're not spending $6 a gallon for 100octane.
Old 05-20-2008, 07:56 PM   #27
I guess I'll have to prove you wrong.. lol.
But I'm fabricating an MP62 FMIC capable manifold and outlet soon so I might not.
Old 05-20-2008, 08:21 PM   #28
Spilner521
Boost Guru
Spilner521's Avatar
I respect that you're building up the engine the right way, but I'm going to have to agree with Spy on this one. The M45 simply can't flow enough to make the power to run 12's, running drag slicks or not.
The M62 idea sounds like a good one. I'd like to see how that turns out for you.
Old 05-20-2008, 09:14 PM   #29
It doesn't matter what the MP45 can or can't do, a ton of nitrous and meth and tuning and you can hit it no problem... I don't intend to have "just a supercharger" getting me good times...
Old 05-20-2008, 09:42 PM   #30
Spilner521
Boost Guru
Spilner521's Avatar
Mixing all kinds of power adders/chemicals means a greater chance of blowing something up. By all means, if that's what you want to do, go for it.
I'll stick with "just a turbo" and get better times than you
Old 05-21-2008, 07:16 PM   #31
spyhunter
spyhunter's Avatar
so then you wouldn't prove me wrong as you're adding another poweradder to the mix.
The most power you'll get out of that supercharger on the car I would say on the high power side would be 250-270ish... and that's w/ a manual tranny.
Not enough to get you into the 12's.
Old 05-21-2008, 07:25 PM   #32
you said anyone running the GM supercharger kit won't get 12s... i'm still running the GM supercharger kit if I use methanol and nitrous as well... so my post remains valid.
Old 05-21-2008, 07:46 PM   #33
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
haha touchet
Bad99Olds is offline   Reply With Quote
Old 05-21-2008, 11:14 PM   #34
spyhunter
spyhunter's Avatar
come on think w/ a level head. By adding another power adder you're suddenly not just running the GM S/C kit.
It doesn't have the oomph to support 12's, or bigger numbers that's required. Besides the moment you start adding bigger injectors and modifying the tune you're technically not running the kit anymore but a hybridized version of it, which in essence means you're not running the GM S/C kit.
Sell the kit, get a GT30, an intercooler that supports 400hp and git 'er done easy.
Old 05-22-2008, 06:29 AM   #35
I don't really have the desire to hit 12s, just 13s, which is pretty easy to do. And I like superchargers.
Old 05-22-2008, 03:34 PM   #36
GA_turbo
GA_turbo's Avatar
GA_turbo is on a distinguished road
for those with the 99 2.4 remember there is a sticky about the 99 to a 00 swap on here read up on it and you can install your charger on a 99.
GA_turbo is offline   Reply With Quote
Old 05-22-2008, 07:41 PM   #37
spyhunter
spyhunter's Avatar
turbochargers are more versatile.
Old 05-22-2008, 07:48 PM   #38
spyhunter
spyhunter's Avatar
http://www.j-body.org/forums/read.ph...5&t=151045&p=2
lol, this is for you.
Old 05-24-2008, 11:02 AM   #39
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
just curious...what kind of ballpark cost would one be looking at for a reflash, if they aren't getting the free one offered by Pace?
Old 05-24-2008, 11:14 AM   #40
the reflash is not free even though it says it's included in the supercharger price. it's whatever the dealership wants to charge you. it cost me $88 to get it.
