Old 05-30-2008, 06:12 PM   #1
Thelowone
Thelowone is on a distinguished road
to good to be true
while looking through the j-body classifieds i found this http://cgi.ebay.com/ebaymotors/ws/eB...m=200227430017
is there any way to tell if these are the real deal???
Thelowone is offline   Reply With Quote
Old 05-30-2008, 06:30 PM   #2
TheAftermath
TheAftermath's Avatar
TheAftermath is on a distinguished road
The casting numbers are correct so I would think they are the right ones.
There are no ceilings where we are.
TheAftermath is offline   Reply With Quote
Old 05-30-2008, 06:34 PM   #3
they're all over the place for that price. of course it's real. secret cams are posted up on j-body classifieds almost every day for $100
Old 05-30-2008, 07:54 PM   #4
TheAftermath
Yeah it's really not that expensive to do the cam swap, and it's pretty beneficial.
Old 05-30-2008, 08:57 PM   #5
2fst4u
[boosted 2.4L]
2fst4u's Avatar
the problem with the cam swap is the difficulty of installation. all the timing components need to be removed when installing the cams. it can get fishy if you don't know what you're doing, but by all means.....
Old 05-31-2008, 01:24 AM   #6
Vinalero
Vinalero's Avatar
How do you know the right position for the cams when you put the chain back on? I always wondered that. I guess screwing your valves is not something you want to happen...
Old 05-31-2008, 09:58 AM   #7
there's markings and i have an engine overhaul manual that tells you how to do everything if you want it lol
Old 05-31-2008, 11:41 AM   #8
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Usually you put the motor at top dead center and there should be marks on the cam gears which you line up so they are pointing at each other and it should turn right on. I am just speakign in general for motors I have no idea if the cam sprockets are marked on the 2.4.
Old 05-31-2008, 12:25 PM   #9
Marrko
Marrko's Avatar
Marrko is on a distinguished road
Send a message via Yahoo to Marrko Send a message via Skype™ to Marrko
what the cam swap does? gives more hp? i'm rebuilding my blown engine so i'm thinking maybe geting them if it does something sorry i'm a noob on engines don't know anything about them :P
The Black Devil ---> American Heart and Soul representer in Europe....
Marrko is offline   Reply With Quote
Old 05-31-2008, 12:48 PM   #10
then maybe rebuilding is a bad idea.
Old 05-31-2008, 01:03 PM   #11
Marrko
Marrko's Avatar
i'm not the one who is rebuilding my macanic is now i'm just looking for the parts and ect... :P
Old 05-31-2008, 03:30 PM   #12
Alero_1986
Alero_1986's Avatar
Originally Posted by Marrko View Post
my macanic is
Is that a new slang for Mechanic? haven't heard that one before...
Old 05-31-2008, 03:32 PM   #13
native language != english
Old 05-31-2008, 03:33 PM   #14
if you put high performance cams in, dont you have to change other stuff too..... you cant just put the cams in and say....ok, im done. lol
Old 05-31-2008, 03:37 PM   #15
Thelowone
thanks guys for the reply..i just wanted a second opinion, i didn't wanna end up with the stock cams or get screwed over.
it wont be that bad because the timing chain snapped so i'm gonna replace the chain, head, water pump and cams all at the same time.
Old 05-31-2008, 04:49 PM   #16
a tune would be nice but nope
Old 05-31-2008, 06:03 PM   #17
If you're rebuilding and you're having a Mech do it. Go for the secret cam swap and get it all covered now. Instead of having to pay to have someone go back in and do it later.
Do it man!
Old 05-31-2008, 06:07 PM   #18
Vinalero
Vinalero's Avatar
when you put your exhaust, you put it on your car and said: "Ok im done" I suppose.
High performance cams are only more aggressive cams.
http://auto.howstuffworks.com/camshaft1.htm
Old 06-02-2008, 06:53 PM   #19
GA_turbo
GA_turbo's Avatar
GA_turbo is on a distinguished road
the cams are a nice swap, i did it to my cavalier and also did the 2.3 throttle also and bump the fuel pressure about 5 psi more to compensate for the low end loss and OMG this thing was crasy fast, S&^% i even got better gas mileage.
this pic was with just the HO throttle and the cams.
http://b6.ac-images.myspacecdn.com/0...27970326_l.jpg
this pic is with the ho maifold, throtle, cams and bumped the pressure up 5 psi.
http://a442.ac-images.myspacecdn.com...871aa8c821.jpg
GA_turbo is offline   Reply With Quote
Old 06-02-2008, 07:29 PM   #20
Thelowone
i never would of thought of bumping up the fuel pressure a lil bit..how did you do it FPR or HP Tuners??
