Old 08-26-2008, 09:04 PM   #61
Originally Posted by BlackJack View Post
just make sure you give it all a minimum of 3 coats each, and probably want to repaint your thermal wrap so it will all match nicely.
That stuff works like a champ. I painted/wrapped/painted the headers, drove the car to work and was able to touch the headers right after shutting down the car. (dumb I know, but I had to see how well it all worked).
Here's the direct link:
http://store.summitracing.com/partde...5&autoview=sku
hot spot by seamore paint works great to.
www.seymourpaint.com
Old 08-27-2008, 01:07 AM   #62
sorrowfulkiller
sorrowfulkiller is on a distinguished road
Send a message via AIM to sorrowfulkiller Send a message via MSN to sorrowfulkiller Send a message via Yahoo to sorrowfulkiller
LS6 MAF (80 or 85mm, IIRC, either way, no notable size drop from my 85mm TB) is a 5-wire, with 3 going to the MAF (power, ground, signal) and 2 for IAT built in. That I'm aware of, the built-in IAT is still a 5 volt signal.
I would have to use my stock iat sensor anyways... my tuning software cannot scale iat sensors as far as I know anyways
Live for something or Die for nothing
sorrowfulkiller is offline   Reply With Quote
Old 08-27-2008, 09:13 AM   #63
check the signal range on both IAT's. You may not have to scale. Compare low temp@volt versus high-temp@volt and see if you even need to worry about changes or scaling. Who knows, you might be surprised.
Old 08-27-2008, 08:17 PM   #64
sorrowfulkiller
oh well... I'm actually looking at an open source ecu patch to run speed density so it should be quite badass... either that or I will setup a map sensor so I can rewire my maf wires to a map sensor and run straight off those signals but I gotta look at how the gm 3 bar map sensor is calibrated
Old 08-28-2008, 01:38 AM   #65
AftermathAlero
SHES ALIVE! Finally!
(dont mind the gauges, the car isn't started)
Shes alive! finally! Fired her up tuesday night, Had a tweak an issue of the misfiring. Ended up being 2 of the injector harnesses wasn't plugged in all the way. Then she purrred like a kitten.
At 2k rmp, she begins to spool. At 3k rpm, she starting to sound like a tornado sucking everything in. At 4-5k.. shes just LOUD! Like a jet. Is the car quick, It is quicker; Not that quick as i have all the fiberglassing, stereo, 20" chrome wheels. And only 6psi.
Old 08-28-2008, 01:41 AM   #66
alerored04
alerored04's Avatar
Beautiful. Done with the same attention to detail and craftmanship that we have all come to expect from you. and FYI I heart your gold UIM.
My car breaks alot.
Old 08-28-2008, 01:44 AM   #67
-Alero-
-Alero-'s Avatar
kewwwwl you drive around with no air filter? or you goin by the chipper/shredder rule?
AUTOBOT
Old 08-28-2008, 01:49 AM   #68
AftermathAlero
Just gonna put a screen on there. No room for a filter. Just need to get my ass to home depot and get a 4" clamp. Which i'll do that tomorrow.
Old 08-28-2008, 01:52 AM   #69
-Alero-
-Alero-'s Avatar
why not get a musroom filter like greddy or hks filters, short and stubby?
and uh whats the deal with the coolant rail what was the reason you hacked it?
AUTOBOT
Old 08-28-2008, 01:57 AM   #70
Vinalero
Vinalero's Avatar
That is a huge turbo! Good quality job man.
Old 08-28-2008, 01:59 AM   #71
AftermathAlero
No room for a filter.. I got 2" btw the frame of the engine bay and the turbo inlet.
The coolant rail to the heater core is modifed to fit the downpipe tube. cut the line and routed a soft line to the front.
Old 08-28-2008, 03:12 AM   #72
You're welcome.
Old 08-28-2008, 08:33 AM   #73
not really...
looking good richie... but.... now the gold UIM looks outta place. Too bad your turbo lines can't be gold too. and the gauge next to your voltmeter doesn't really seem to "go" with the color scheme....
maybe i'm just being too nit-picky.
.... but now after i mention this, your probably going to find ways to change it all, and FORCE me to shut up.
and what the heck are those rectangular gauges under your headunit? i see oil pressure ...and...? where did you find those? thats pretty slick
Old 08-28-2008, 10:12 AM   #74
-Alero-
-Alero-'s Avatar
air ride monitor, digital psi readout
AUTOBOT
Old 08-28-2008, 10:18 AM   #75
-Alero-
-Alero-'s Avatar
i had a question about the oil catch...umm have you picked up any oil?
correct me if im wrong but doesnt THAT pcv suck up little to no oil? again correct me if im wrong, cause i mean ive changed that line before but i didnt find any oil residue in it, but i could be wrong, well i mean i have seen dark build up in the lim but i always thoguht it was from the egr
AUTOBOT
Old 08-28-2008, 11:28 AM   #76
AftermathAlero
I have picked up some oil. I had the catch can before the turbo. It caught like 2oz of oil. I dont have my EGR anymore either.
You're welcome.
Like i said in my pm to you. Thanks for the help! hehehehehe
Old 08-28-2008, 03:15 PM   #77
hok666
how did you clear the knobs on the center console?
Old 08-28-2008, 03:43 PM   #78
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
^^haven't seen that question in a long time.
Boost can be addictive. Give him two years. No chrome, no air suspension, no custom paint. Only lightweight wheels and 11 sec quarter mile times or better.
CiscoPath is offline   Reply With Quote
Old 08-29-2008, 12:09 AM   #79
-Alero-
-Alero-'s Avatar
apparently he claims he already went through the speed stage, at one time he had nitrous on it, but maybe hes getting back into it
AUTOBOT
Old 08-29-2008, 12:15 AM   #80
AftermathAlero
LOL.. nah the car is done! .. prolly just some new wheels next yr. Like I planned for this year, but with my back surgery took place and used the money there. So next year is just new wheels. Gold chrome w/ polished lip is the plan still! Then yall cant say my gold engine doesn't match anything else on the car.
