Old 07-03-2004, 02:52 PM   #1
mjt205
Hey peeps, I just got 18'' eagle alloy 077 series wheels on my 2001 alero cupe..5x115. However, i went to get em balanced and i need wheel spacers in there. does any have any info of what size i wil need??? i went to pep boys and they had 5/16'' and 1/4'' spacers. I appreciate ANY help anyone can give me! happy 4th of july everyone
Old 07-03-2004, 03:39 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
do you know what the offset of the wheels are? Whichever spacer gets you to the 35-42 range will help you out. :thumbsup:
Old 07-03-2004, 06:08 PM   #3
mjt205
the offset is +38 as far as i know..i dont think eagle alloy has anything different in the 18x8 wheels
Old 07-03-2004, 07:17 PM   #4
mfuller
Who said you need wheel spacers? You have the correct bolt pattern and the size/offset are fine, so they should bolt right up without a hitch. You may, however, want to add hub-centric rings to be sure the weight of the vehicle is being supported by the hubs and not the wheel lugs.
Old 07-03-2004, 08:55 PM   #5
3.4Alero
/\ /\ Yup. I believe a couple others on here (including Naich?) have the same wheels, and I don't believe any of them needed spacers. I would definately inquire about hubcentric rings though, as mfuller said.
Old 07-03-2004, 09:02 PM   #6
Oldsmopimp
yes. U'll want to get the hubcentric rings. I have those wheels too. So does Naich.( u dont need any spacers) We both got our hubcentric rings from clubgp.com
Old 07-04-2004, 03:19 AM   #7
b-spot
b-spot is an unknown quantity at this point
Did any of you guys have troubles fitting the hub rings on the rears?
If I did went to college...
b-spot is offline   Reply With Quote
Old 07-04-2004, 10:08 AM   #8
3.4Alero
As long as you get the proper rings, they will NEVER be hard to install. You need to get the right ring based on your stock centerbore and the centerbore of the new wheel. As long as you get them based on that info, they should slide right on for a nice tight fit.
Old 07-06-2004, 03:36 PM   #9
mjt205
thanks for ur help everyone...i got the info about hte wheel spacers at walmart tire center. perhaps i shouldnt have gone there. haha...thanks again
