Old 09-11-2008, 10:30 PM   #1
elpuas3000
elpuas3000 is an unknown quantity at this point
oil question...
ok here it is
what kind of oil should i use for my alero and for my mazda i am using shell...
elpuas3000 is offline   Reply With Quote
Old 09-11-2008, 10:40 PM   #2
guiguilandry
guiguilandry's Avatar
Use what it is told in your owner's manuel 5w30. Synthetic or not is up to you, Before the swap I was using Quaker State Q Horsepower 5w30, worked pretty good to me.
But now I use synthetic Racing Valvoline 20w50, but this just because my engine is made for it... I mean oil clearances on the bearings and it helps keeping a little more compression with 13 PSI...
Custom or Nothing...
www.demonautosport.ca
Old 09-11-2008, 10:58 PM   #3
elpuas3000
what about for mazda?
Old 09-11-2008, 11:01 PM   #4
guiguilandry
what year/model of your mazda
Old 09-12-2008, 01:48 AM   #5
CactusWill
Oil is pretty much mostly the same as far as brands are concerned, except for the differences between conventional and synthetics. Now racing oil is different, because it has alot of zinc added to it to help protect your engine. But it wreaks havoc on your emissions system, and could ruin your catalytic converter.
As far as weights, 10w-30 is fine. Most GM V6's recommend you to use 10w30, but 5w30 is good too if you live in a colder area.
But when it comes to differences between brands, if you're just buying a quart of conventional 10w30, it doesn't really matter if you buy a name brand, even the generic oils come from major brand name oil companies.
Old 09-12-2008, 02:02 AM   #6
guiguilandry
.. I'm straight pipe so no danger for my cat lolllllllll
Old 09-25-2008, 04:30 PM   #7
zoomie
zoomie's Avatar
zoomie is on a distinguished road
I'd use 5w30
2003 2.2 5sp.
Tight Lines..............................
zoomie is offline   Reply With Quote
Old 09-25-2008, 05:10 PM   #8
What motor in the Mazda?
Anythng 4 bannger I would probably use 5w30
Old 09-25-2008, 05:59 PM   #9
elpuas3000
it a 2004 mazda mpv 3.0 L AJ V6
Old 09-25-2008, 07:34 PM   #10
Headstrong2740
Headstrong2740's Avatar
Headstrong2740 is an unknown quantity at this point
Send a message via AIM to Headstrong2740 Send a message via MSN to Headstrong2740 Send a message via Yahoo to Headstrong2740
put some 75W in the mazda... winter is coming so you want that heavier oil check your owners manual should tell you. prolly will be a 5w30 or 10w30 maybe even 40.
backslide
"Dude..cuming on my mom is one thing, but banging your grandmother and her two roommates is like.....legandary!"
http://www.cardomain.com/ride/2589855
Headstrong2740 is offline   Reply With Quote
Old 09-25-2008, 07:49 PM   #11
Steven01
Steven01's Avatar
Steven01 is on a distinguished road
Ahhh Just go get some royal purple. thats all you need. problem solved
Steven01 is offline   Reply With Quote
Old 09-25-2008, 08:06 PM   #12
TheEdgeofSanity
TheEdgeofSanity's Avatar
yeah, i'd say Mobil 1 or Royal Purple for the alero. i'm pretty sure it says 5W30 for all alero's, regardless of the engine type.
2000 Chevrolet Malibu LS
Old 09-25-2008, 09:36 PM   #13
undecided02
undecided02's Avatar
undecided02 is on a distinguished road
how many km on the motor. I use castrol gtx high mileage 5w30 but im at around 160,000km
undecided02 is offline   Reply With Quote
Old 09-25-2008, 09:58 PM   #14
use royal purple in all my cars....
Old 09-25-2008, 11:34 PM   #15
I'm a pennzoil. Helps against sludge and traps the little dirt particles.
I use high mileage too, since i'm at almost 250k km
Old 10-01-2008, 08:59 PM   #16
Steven01
Steven01's Avatar
if you wanna get rid of sludge. and to get rid of carbon just add like half a litter of AFT (automatic transmision fluid) to you oil few weeks befor you do a oil change and let you oil drain good. Do it all the time on my 350 motor.
Old 10-01-2008, 11:35 PM   #17
jwateland
jwateland is on a distinguished road
you're gonna want to look up the vehicle specs you should find some numbers that tell you the weight vescosity ex. 5w30 then you will see two letters ex. sl, sw it differs from the vehicle. then when you go to get oil look for a seal printed on the oil it should contain the number code and some other tidbits of writing. but it is usually printed in gold
jwateland is offline   Reply With Quote
Old 10-01-2008, 11:46 PM   #18
GET MOBIL 1 SYNTHETIC! if you have more than 40k on the car dont use synthetic. Dont waste your money on royal purple, mobil 1 is cheaper and nascar recommends it!
Old 10-03-2008, 12:06 PM   #19
circeansleeper
circeansleeper's Avatar
circeansleeper is on a distinguished road
I concur. I was reading to see if someone else mentions Royal Purple....it is expensive, my fallback is Mobile1.
Annoy a Liberal: Work, Succeed, Be Happy!
circeansleeper is offline   Reply With Quote
