03-06-2009, 10:33 AM
some questions
K I got some questions,
This is for a 99 3400 coupe,
First, what I found for removing the headlights is different for these headlights how to remove
Also? How to remove the door panel to access the window reg and motor, its a coupe,
What kind of glue to use on the dash covering.... mine is like a trampoline, its so peeled..
Umm. My fob won't openb my trunk! But it opens my doors, what the hell?
My driver side door lock hole is loose, it just like turns but the lock does not work, I searched and found nothing, what is needed to fix this?
My headlights are foggy, could I like buff them and make them clear?
Thanks!
No newb cracks plz, I rarely post questions and all this stuff I can't find orr I can find and it is not detailed enough
03-06-2009, 10:54 AM
Thanks!
1. What
2. Remove screws behind the door handle cover
3. A tacky apholstery glue
4. Is your trunk lock set to lock?
5. Check the mount for it when you remove the door panel
6. The headlights supposedly can be cleared up using a very fine grit sand paper, but I remember a product was made for just this situation that should be at Autozone or such.
Have a good day
03-06-2009, 11:05 AM
1. headlights come out the same way on all years, pull up tabs, unscrew bulb/wiring connections, pull out.
03-06-2009, 11:48 AM
Thank you sir!
I figured he was asking that but it sounded like a statement.
"ENGLISH MUTHA effER! Do You Speak IT!"
Have a good day
03-30-2009, 07:19 PM
so, im back to this, is there a how to to change your window regulators?
03-30-2009, 07:25 PM
Originally Posted by AGT
1. What
2. Dont forget theres a screw behind the reflector in the corner of the door
yes there is
03-30-2009, 07:29 PM
Originally Posted by [ion] C2
yes there is
point me in the right direction please ?
