Old 03-21-2009, 09:26 PM   #1
irondiezl3
irondiezl3's Avatar
how do you change the hazard
how do you change the hazard switch? sumthin abut taking off spedo trim?
Old 03-21-2009, 09:33 PM   #2
take off the speedo trim, you might need to remove the gauge cluster.
you should be able to reach it from behind. take the wire harness off of the back of it.... and give the front of it a good smack. it should pop right out.
Old 03-21-2009, 09:36 PM   #3
irondiezl3
irondiezl3's Avatar
is the harness just like a clip on harness? take that off the just push it from behind hard? or do you push it from the front and it falls backwards?
Old 03-21-2009, 09:43 PM   #4
yes, just a clip harness.
the front button pulls out straight (might need to pry it out w/ a screwdriver. but the whole switch comes out from the back. you need to push the front and it'll pop out.
Old 03-21-2009, 09:51 PM   #5
irondiezl3
irondiezl3's Avatar
i already took the gray trim piece off and the red button off the rest it doesnt matter if i damage when i push since im replacing it right? omg i cannot wait to replace this f*cker
Old 03-22-2009, 07:58 AM   #6
if your replacing it... who cares if you break it? just don't break the mount (which you shouldn't)
i just put a big screwdriver blade against one of the flat spots on the front, and hit the end. it came right out.
Old 03-22-2009, 08:44 PM   #7
i didn't take anything off but the little piece that goes around the switch...
Old 03-22-2009, 10:43 PM   #8
whiterider00
whiterider00's Avatar
seriously...? mine i had to take off the piece around the gauges, then i tried pushing it thru from the front, but ended up having to take a tiny ratchet with i think 7mm socket and take out the 3 screws holding the mounting bracket to the dash from behind the dash. took me a good half hour, i dunno how u guys are doing it like that, but glad it was easier for you.
Old 03-22-2009, 10:56 PM   #9
if you poke it hard enough it slides out of the bracket(towards the front bumper) then you just disconnnect the plug. the hardest part is pulling it back towards you to get it back in the bracket... and upon remembering doing this, I took out my center ac vent.
Old 03-22-2009, 10:58 PM   #10
irondiezl3
irondiezl3's Avatar
cant wait to get it
Old 03-23-2009, 09:12 PM   #11
irondiezl3
irondiezl3's Avatar
cher did it just like you said worked just needed a hammer and screwdriver to push it out unfortunately didnt fix problem so i cleaned multi switch seemes to have worked wowwwwwwwww the switch was filthyyyyyyyyyyy unfortunately i broke my center vent i slipped hitting the hazard switch out dealer wants 45 bucks ffffffffffffffffffff that shit i hope a junky will have one thats not broke.
Old 03-23-2009, 09:22 PM   #12
your suppose to put the screwdriver in place, before you hit it...
not just swing like a mad man!
Old 03-23-2009, 09:36 PM   #13
irondiezl3
irondiezl3's Avatar
lol hey i learned the hard way. cher i think you should be a alero spokesman you know everything about our damn cars!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-23-2009, 10:02 PM   #14
is that why mine is currently disabled?
Old 03-23-2009, 10:50 PM   #15
Dhoyle
Si vis pacem, para bellum
Dhoyle's Avatar
Dhoyle is on a distinguished road
time for an engine swap out cherr :P
Dhoyle is offline   Reply With Quote
Old 03-23-2009, 11:20 PM   #16
irondiezl3
irondiezl3's Avatar
uh o went for a drive no more clicking but guess what no horn? steering wheel kinda tight did i overtighten the multiswitch? i followed directions perfect on gagt forum?
Old 03-24-2009, 02:10 PM   #17
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
um what are you switching the switch with? pic?
