Old 04-10-2009, 05:13 PM   #21
alerored04
alerored04's Avatar
if you want a 10c fix for the cruise control stick a dime between the on/off button and the housing to hold it down.
My car breaks alot.
Old 04-10-2009, 05:33 PM   #22
worknprog.99
worknprog.99's Avatar
Originally Posted by Blown 346 View Post
I tried that, The cruise doesnt engage. I just watch the speedo drop. The light on the cruise button wont stay on unless I constantly hold it. Even then the cruise doesnt work.
yes mine also does that, also my heater controls do the same thing
Old 04-16-2009, 04:32 PM   #23
goldalero99
goldalero99 is on a distinguished road
#1 and #4 are very common problems on these cars. #1 sounds like the blower motor resistor. The part is not that expensive. You'll need a small ratchet set and then search this forum and you'll find instructions to replace it. #4 is a bit more complicated. When I looked into fixing this, I found that I would have to remove airbag assembly and other parts from the steering wheel to replace the switch. Not worth it in my case. I took the advice offered previously on the forum and used a dime to wedge the button when necessary (which isn't very often). good luck
goldalero99 is offline   Reply With Quote
