Old 06-08-2009, 11:00 PM   #1
kickroqs
kickroqs is on a distinguished road
tune-up
About to do my 1st tune up. Do I need to replace the O2 sensors? Got plugs,plug wires, and fuel filter. Am I forgetting anything?
kickroqs is offline   Reply With Quote
Old 06-08-2009, 11:06 PM   #2
Valley olds
Valley olds's Avatar
Air filter. Also, how much mileage do you have on your car? If the O2 sensors arent backfiring, I wouldn't replace them. I have heard some people clean them. Maybe someone here could clarify on that being a good idea or not.
Old 06-08-2009, 11:09 PM   #3
KenshinZero
KenshinZero's Avatar
KenshinZero is an unknown quantity at this point
You should check you’re o2 sensor at least. Personally I would get one weather its good or bad, just as preventative maintenance.
1999, RED Alero GX
KenshinZero is offline   Reply With Quote
Old 06-08-2009, 11:11 PM   #4
they re like 70$!!! f that...
Old 06-08-2009, 11:12 PM   #5
KenshinZero
Think of it as a safety net of sorts, if it dose go bad in the future, you already have one
1999, RED Alero GX
Old 06-08-2009, 11:14 PM   #6
eeh, my saturns Upstream is bad, the light comes on once a month, then goes out... who cares
Old 06-08-2009, 11:17 PM   #7
KenshinZero
Have you tried thretening it, of kicking it. That may help, lol
Back on subject, from the sound of it, you have everything you need, I cant think of anything.
1999, RED Alero GX
Old 06-08-2009, 11:40 PM   #8
I thought i saw KROQ in that username
Old 06-09-2009, 12:38 AM   #9
sh8dybizness
sh8dybizness is on a distinguished road
How many miles on your car? Also it wouldn't hurt to change the o2 sensors. They play an important role in stretching gas mileage and preventing your cat from early damage. Plus they help engine performance since the pcm uses them to control air/fuel mixture.
sh8dybizness is offline   Reply With Quote
Old 06-09-2009, 09:58 AM   #10
kickroqs
tune-up
She's has about 125500 miles. Just did the oil change and replaced the air filter a week ago.
Old 06-09-2009, 12:26 PM   #11
The recommended lifespan for the Oxygen sensor (heated) is 100,000 miles. However, the PCM will usually do a fairly good job at detecting a fault.
Old 06-09-2009, 12:57 PM   #12
jackal2000
Keepin it Real
jackal2000's Avatar
while that is true, i believe that if it is operating at one extreme or another of it's tolerated voltage there is a benefit to be had by replacing it.
2015 Audi SQ5
