Old 09-03-2009, 02:12 PM   #1
dbizz23
dbizz23's Avatar
dbizz23 is an unknown quantity at this point
Send a message via AIM to dbizz23
my brakes
My front brake pads are directly on my rotor and are slowing me down real bad when i drove this morning...this is about half of my brake pad left on both...what's my problem how do i solve it?
Pluggin Fresh Holes
dbizz23 is offline   Reply With Quote
Old 09-03-2009, 02:31 PM   #2
bkathsalero
bkathsalero's Avatar
That could alot of things.. Stuck calipers, Rod failure in booster. First just try and lube the caliper slides
Old 09-03-2009, 02:36 PM   #3
dbizz23
dbizz23's Avatar
this is my buddies 99' mercury cougar by the way, i took his wheels off and hit his calipers with a hammer to knock all the rust off...i sprayed the shit out of the caliper with wd-40. Didnt work the pad is still directly on his rotor
Pluggin Fresh Holes
Old 09-03-2009, 02:38 PM   #4
CactusWill
You need to be posting on a ford forum, not an alero forum, if you want real help.
Based on my limited knowledge about fords, you need to replace the calipers.
Old 09-03-2009, 03:12 PM   #5
dbizz23
dbizz23's Avatar
Ughhh
Pluggin Fresh Holes
Old 09-03-2009, 03:14 PM   #6
bkathsalero
haha internet stress
Old 09-03-2009, 03:16 PM   #7
dbizz23
dbizz23's Avatar
hahah yup
Pluggin Fresh Holes
Old 09-03-2009, 05:07 PM   #8
dbizz23
dbizz23's Avatar
anyone else with an answer? any input would be appreciated
Pluggin Fresh Holes
Old 09-03-2009, 10:40 PM   #9
Afugy
I poop alot
Afugy's Avatar
Calipers, take the calipers and press the piston in, see if it binds at all. Use a piston press, I have never use a c clamp, they are only like 5$.
Old 09-03-2009, 11:58 PM   #10
take the calipers apart like you were gonna replace pads, and lube the slide post things. that might help, just randomly spraying wd-40 won't usually.
