Old 01-25-2010, 03:07 PM   #1
Bruscomusco
Bruscomusco's Avatar
Bruscomusco is on a distinguished road
Emergency Brake Light Staying On
I went to start my Alero the other day and when I put my E brake down the "brake" light was still lit. It's been sitting for about a month and the battery has died twice. I didn't get to drive it to see if it would shut off.
Any ideas?
Bruscomusco is offline   Reply With Quote
Old 01-25-2010, 03:20 PM   #2
AndyT3
AndyT3's Avatar
AndyT3 is on a distinguished road
Send a message via AIM to AndyT3 Send a message via Yahoo to AndyT3
Check brake fluid level.
FQuick - updated all the time
AndyT3 is offline   Reply With Quote
Old 01-25-2010, 04:20 PM   #3
If the level's good, the sensor is effed
Mine is unpluged
Old 01-25-2010, 04:27 PM   #4
He's talking the ebrake so isn't that a diff light? I'd think it has something to do with the sensor down under the lever that knows when the lever is lifted
Old 01-25-2010, 05:25 PM   #5
AndyT3
AndyT3's Avatar
I think it's the same light.... isn't it? It just says BRAKE...?
Old 01-25-2010, 06:38 PM   #6
Philbar71
The Ebrake light is on the tach, right?
And the brake light is on the speedo?
Or i could be wrong.
Old 01-25-2010, 06:46 PM   #7
Ttop191
Ttop191's Avatar
All i see is BRAKE on the tach...
Old 01-25-2010, 07:00 PM   #8
Bruscomusco
Just says "BRAKE"
I'll check fluid levels next time I go to start it
Old 01-25-2010, 10:37 PM   #9
Either low fluid, ebrake is on, or pressure differs between brake circuits (aka a line is leaking or something).
You probably notice pull if the pressure differential was the case.. I agree with all of them, fluid level!
Old 01-26-2010, 01:48 AM   #10
whiterider00
whiterider00's Avatar
ya, check the fluid. thats what mine was.
Old 01-26-2010, 09:51 AM   #11
Bruscomusco
Thanks all
Old 01-26-2010, 10:48 AM   #12
a4d2a0m
a4d2a0m's Avatar
a4d2a0m is on a distinguished road
Ya... it is th e-brake and a brake system warning light mine does not say brake tho, it is..... (!)(P)
a4d2a0m is offline   Reply With Quote
Old 01-26-2010, 10:48 AM   #13
mine used to stick, it's the position sensor
Old 01-26-2010, 03:54 PM   #14
AndyT3
AndyT3's Avatar
Or it could simply be the fluid level.
If your car shows the (!)(P) it was made in Canada. Or at least thats how it goes now-a-days. If its in pictures rather than words, its a Canadian built car, GM at least...
Old 01-26-2010, 05:29 PM   #15
a4d2a0m
a4d2a0m's Avatar
I always wondered why?... Or if there was anything else the did different.
