View Poll Results: When should i drop the engine in?
As soon as i get it
33 |
55.00% |
Wait till spring/end of snow
27 |
45.00% |
12-08-2009, 09:56 PM
#101
You never revved it right? And dont lie. Also did you start it and let it idle for a while? ANd I mean just let it sit and let it run for a good while.
You are suppose to start it then stand in front of the car and just watch her per and see how she idles. Just stand there and stand then watch the gauges then stand....LOL. Look for leaks, listen to the idle, notice if the fans come on, check gauges frequently, give it some gas, etc.
12-08-2009, 10:07 PM
#102
ya i did that and it ran perfect changed the oil the drove it around for 30mins changed the oil again then i drove it this morning and boom
12-08-2009, 10:23 PM
#103
I know its been told here to change the oil a few times when you first start it but honestly I only changed it once after starting it and I never had problems.
But 6 quarts is sufficient due to the modified oil pan. Now do you know for sure if a new oil pump was used? If so what pick up was used too?
Was the timing perfect on mark?
12-08-2009, 10:30 PM
#104
i had the 2.3 swap so as far as i know everything was new and im not sure about the timing but i think it was good cause it started up great and ran fine until it died lol
12-08-2009, 10:39 PM
#105
:/ bunk. Are you going to tear it down to find what happened?
12-08-2009, 10:49 PM
#106
yup im tearing it out thursday and giving it back to OEM and there going to take care of it
12-09-2009, 01:09 PM
#107
Take pictures of the chain before removing it and other areas too. Are you tearing it down or will that guy from OEM do it?
And its funny cause I think I remember reading over on the org that he left something loose so there will be less friction etc....I'll go back and read it again.
12-09-2009, 01:13 PM
#108
Well ill be pulling the engine out tomorrow,ill be sure to take lots of pics and make up a how to this time.
12-10-2009, 04:39 PM
#109
updates now!!!
12-10-2009, 08:14 PM
#110
Well i found out what happened
Markus is going to take the block back and see what he can salvage
12-10-2009, 11:37 PM
#111
What's pokin out the side der? Looks like the connecting rod came apart?
12-11-2009, 12:34 AM
#112
Haha like the connecting rod bolts
But seriously, this wasn't Mark's fault... more to come.
02-05-2010, 12:06 AM
#113
Getting rid of the HO
Kinda  little update OEM is going to be stopping by sometime this month to pick up my car and bring it down to his shop in FL i got big plans
02-05-2010, 01:01 AM
#114
did you bother to torque things down to proper specs. in that built engine or did you just wing it?
02-05-2010, 08:11 AM
#115
To my understanding he had the engine built. He wasnt the one turning wrenches on the motor..
Anywayz when are you expecting to get the car back running since the car is taking a trip to Florida??
02-05-2010, 10:18 AM
#116
ya he had the engine built in NY the engine was nice saw it you should have seen the old engine that was in there oh god it was so bad.
02-05-2010, 04:10 PM
#117
Ill have the car back some time in may so that way i can take it to ASS
02-05-2010, 04:23 PM
#118
nice bet it is going to be fast.
02-09-2010, 12:00 PM
#119
i was reading through here thinking that your build would be nice to do to mine  but the hole in the block looks bad. I am going to be pulling my LD9 and attempting to rebuild it with the help of a buddy of mine granted he builds V8's but i am sure a I4 won't be too much of a problem for him and i to tackle if you read through one of my threads Motor Blew it tells the whole situation with mine. Can't wait to see the updates on yours.
stock 2.4  -building a WAI to a CAI  3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers  10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
