Old 09-17-2004, 06:24 PM   #1
-Alero-
-Alero-'s Avatar
can someone tell me how to remove the dome light safely so i can replace the bulbs, and what are the blub #'s for all 3 of the bulbs, i belive i heard a 512 or a 216 but im not possitive. any advice will help thanks :thumbsup:
AUTOBOT
Old 09-17-2004, 06:26 PM   #2
smokinAMD
smokinAMD is an unknown quantity at this point
Send a message via ICQ to smokinAMD Send a message via AIM to smokinAMD Send a message via MSN to smokinAMD Send a message via Yahoo to smokinAMD
Just pull it down. If the friction clips crap out, which is likely. You can just get a small self tapping screw and screw the dome light assembly back into cross member it mounts on.
smokinAMD is offline   Reply With Quote
Old 09-19-2004, 02:34 AM   #3
-Alero-
-Alero-'s Avatar
so basically i have to break it to take it out and replace the bulbs?
AUTOBOT
Old 09-19-2004, 05:24 AM   #4
FormulaNERD
no, you dont have to break it, but if it's been pulled more than a few times the little clips will start to break, and it'll be less secure up there unless you screw it in like brent said.
Old 09-19-2004, 02:24 PM   #5
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Stick a thin tip slotted screw driver in one side of the cover where the small slotted hole is and then pull the cover off.
Old 09-19-2004, 03:01 PM   #6
alerosport.com
move it from side to side and the clips should release it. but they will break over time if removed allot or forcefully.
Old 09-19-2004, 03:13 PM   #7
|Rev|
what are the bulb numbers?
Also, kind of off topic, but what are the bulb numbers on the map reader lights on the rear view mirror?
Old 09-19-2004, 03:19 PM   #8
turtles_ride
turtles_ride is an unknown quantity at this point
Send a message via MSN to turtles_ride
i took a picture of mine when i redid my roof. I forced it off the first time i took it down and the clips had been weak ever since. if it happens to you i put a picture in this thread about where you can safely put a screw to hold it up. Its about half way down the first page
http://invision.aleromod.com/index.php?showtopic=5274
turtles_ride is offline   Reply With Quote
Old 09-19-2004, 03:40 PM   #9
FormulaNERD
194
