Old 06-12-2010, 02:20 PM   #1
sith123
sith123's Avatar
sith123 is on a distinguished road
power mirrors wont work
hi i just buyed a 3.4 alero sedan and found that the mirrors dont work
i checked the fuses and the drivers side where the buttons are but cant find anything.did i miss something ?
sith123 is offline   Reply With Quote
Old 06-12-2010, 03:16 PM   #2
might be the harness is fried. My auto-window was intermittent on the drivers side, due to water dripping down onto it.
take the switch out, and clean the contacts (take apart the switch and clean it too) and see whats up.
we have a HORRIBLE design with roof/door/side that causes water to bead up on top of the car, then drip off the side when you get in... if your window is cracked open, it pours directly onto your window controls. no idea why they did this... its idiotic.
Old 06-12-2010, 03:23 PM   #3
sith123
sith123's Avatar
hmmm oke ill try tomorrow to get it loose again
because both mirrors wont work ,so it cant be that hard right
Old 06-12-2010, 03:42 PM   #4
normally not. you can just pop the panel out (pull it up and out of the door) and remove the switch out the bottom.
