Old 07-28-2010, 08:05 AM   #1
K8TEK
K8TEK is on a distinguished road
Removing Dome Light
I seen several threads talking about how to remove the clear lens to the dome light, but how do you remove the escutcheon that the lens attaches to? I need to get underneath the dome light to drill a hole through the roof.
K8TEK is offline   Reply With Quote
Old 07-28-2010, 12:15 PM   #2
If I remember correctly (been awhile since I took the headliner down) It should just be clipped in (two clips)...just tug on it....if you break the tab that the clip is on you are screwed though. I can't remember if there is a screw there or not you'll have to look if once you pop the lense off and you don't see any screws then I'm sure it is clipped.
Old 07-28-2010, 12:33 PM   #3
K8TEK
It's clipped. Where the clips are, there are arrows pointing different directions and they say remove. I was wondering if that meant anything special.
Old 07-28-2010, 02:43 PM   #4
Should just pull down... 2 christmas tree clips, IIRC. worst design ever, be careful.
