Old 10-14-2010, 04:17 PM   #1
HVAC issues
when I pulled the trim plate off to install a new stereo I pulled it a bit to far and a vaccuum hose came loose, now it doesnt change temperate but the fan blows and there are no lights on the HVAC and selectors dont work, does it have to go to a shop or is it a simple fix?
Old 10-14-2010, 04:36 PM   #2
Lucalare
Lucalare is on a distinguished road
Send a message via MSN to Lucalare
Reconnect that vacuum hose, that's what runs the different settings for your HVAC. If there's a malfunction it defaults to defrost, which runs your a/c compressor, so you'll wear it out faster, plus lose mileage/power. As for the lights you obviously disconnected/broke a wire as well, so you'll have to track that down and fix it.
1987 Honda Rebel 450
Lucalare is offline   Reply With Quote
Old 10-14-2010, 05:44 PM   #3
thanks, the vac hose never came all the way off it just loosened up enough to lose pressure, I put it back on tight...I checked all fuses and they were still good, so I guess tomorow I'm chasing wires...
Old 10-14-2010, 09:48 PM   #4
Lucalare
Does it at least work properly now(except lights)
Old 10-14-2010, 11:18 PM   #5
yea, It doesnt heat up or cool down very much, just vent temperature, but I can switch the vents and blower speed
Old 10-15-2010, 12:13 AM   #6
Lucalare
Well that could be a clogged heater core too, try flushing it. If you don't know how I can write a little how to, although there won't be any pictures.
Old 10-15-2010, 12:35 AM   #7
I doubt its the heater core, It worked great before this happened, but I guess anythings a possibility, I'll update If I find a loose or broken wire tomorow, thanks for the help
