Old 06-20-2011, 04:22 PM   #1
spyder_013
spyder_013's Avatar
spyder_013 is on a distinguished road
The Big 3 Upgrade
Alright, after adding my sound system, my next job is to upgrade the Big 3. I am using 1/0 AWG wire all the way around for it. I did some searching on here, and couldn't find my specific answer, maybe I searched the wrong things, so... here goes:
Ok, the Battery Negative to Chasis is easy, but the Chasis to Engine is the one that is a bit confusing to me. I have the 2.2l Ecotec in my '03 Alero, where do I ground from? Many guides/forums I looked at said to ground off of one of the mounting bolts of the Alternator, but the little info I found on here said to use a Transmission bolt, but I don't really know what bolt to use?
I feel the Alt + to the Batt + is pretty easy, I just have to add a wire to where that boot is on the Alt that says "Batt +", correct?
Thanks!
2003 Alero GL1
Sound System: Kenwood KDC-MP245 Deck | Kenwood KAC-8452 Amp | Pioneer 400W Subs | Sony Xplod Speakers
spyder_013 is offline   Reply With Quote
Old 06-20-2011, 04:52 PM   #2
spyder_013
spyder_013's Avatar
So, when those guides say Alt Mounting Bolt, does that mean I can use one of the ones highlighted in red?
2003 Alero GL1
Old 06-20-2011, 06:35 PM   #3
Correct on the + alt.
grounding alt to body is the same as engine to body, since the mount IS a ground, to the engine.
Old 06-20-2011, 08:10 PM   #4
i did mine from the one of the bolts near the valve cover to the strut tower
Old 06-20-2011, 08:26 PM   #5
spyder_013
spyder_013's Avatar
Ok, but so pretty much grounding to pretty much any bolt on the engine will work for grounding? So just grab something that say holds a bracket on that is on the rear of the engine so its closest to the strut tower?
2003 Alero GL1
Old 06-20-2011, 08:33 PM   #6
it has to run from the engine to the chassis so yea. or you can use near the trans harness theres 2 grounds that run from there too
Old 06-21-2011, 10:47 AM   #7
spyder_013
spyder_013's Avatar
Sorry to beat a dead horse... but I like to over think things and make absolutely sure I am doing it right.
Can I use the screw circled in red? It just holds on the exhaust header cover... right? It is obviously connected to the engine.
2003 Alero GL1
Old 06-21-2011, 11:33 AM   #8
you can use that but there should be a ground already on the engine. Follow the negative wires on the battery.
Old 06-21-2011, 01:25 PM   #9
spyder_013
spyder_013's Avatar
So, can I/should I just follow that wire? Obviously use the same point on the engine, should I just have the new/extra ground wire go back to the battery? or should I ground to the chasis, ie the strut tower?
2003 Alero GL1
Old 06-21-2011, 01:42 PM   #10
The best ground is on the chassis of the car but if you do that make sure you sand off all the paint. here are some videos.
http://www.youtube.com/watch?v=iX9Rcq5DnKw
http://www.youtube.com/watch?v=vVAZXtgtvNE
also i would get an aftermarket ring terminal.
http://www.stingerelectronics.com/pr...&CategoryID=10
Old 06-21-2011, 01:45 PM   #11
you will want to get 2 new ring teminals one for positive and one for negative terminals. What subs and amp are you planning to have. Also are you planning to upgrade your battery.
Old 06-21-2011, 03:05 PM   #12
spyder_013
spyder_013's Avatar
I am planning to upgrade my battery soon, just not yet, but so I wont invest in terminals since my new battery probably wont use the same ones. Subs and Amp are in my sig, its all wired, just experiencing a bit of light dimming, and the Big 3 is obviously beneficial, so its getting done.
2003 Alero GL1
Old 06-21-2011, 03:19 PM   #13
well if you get aftermerket teminals you can use them on almost any battery you buy. For the battery i would go with XS power or optima redtop of yellowtop. I had the red top and it was a great battery. The terminals that is posted will work even if you switch the battery.
http://www.sonicelectronix.com/item_...5302-Gold.html
Old 06-21-2011, 03:54 PM   #14
I went through 2 redtops, one died for reasons unknown (didn't hold a charge after a couple years) and the 2nd had a battery terminal melt. Literally melted.
I switched to yellow. No problems.
Old 06-21-2011, 04:08 PM   #15
ya i do not have my redtop anymore. i am getting a XS power battery soon.
Old 06-21-2011, 04:30 PM   #16
spyder_013
spyder_013's Avatar
So, that terminal will work with a standard side post battery (My current one)? I think it is just a Napa Select I got from my uncle.
Is the yellow top recommended by you guys? My sound system isn't very powerful, I just want something that is good and will last.
Aside from the Battery Negative to Ground Wire, there is only one other wire coming off of it, and that wire goes to the engine, right? I believe I found what you said, I just want to keep beating that stupid dead horse....
2003 Alero GL1
Old 06-21-2011, 04:41 PM   #17
ya it should work they sell batteries with battery terminals on the side and on the top of the battery like this.
https://www.napaonline.com/Catalog/C...0389976& An=0 But it will work on a regular battery too but optima is a great battery.
Old 06-21-2011, 04:46 PM   #18
it is good to upgrade your battery now so when you want to upgrade your system in the future and you will not have to spend money on a battery because you will already have one made to handle system.
Old 06-21-2011, 06:18 PM   #19
Afugy
I poop alot
Afugy's Avatar
Ground to the strut tower, also the best spot in the trunk too. If you ground to the front of the car like in the videos posted you are grounding to a piece of metal that is spot welded to the rest of the car. And don't ground to the fender bolts. Everything that EXOcontralto should be taken with a grain of salt.
Watch the video in my sig.
I've had my yellow top for 4 years now, still works like new.
Old 06-21-2011, 07:20 PM   #20
well i was just posting some examples you do not have to listen to them. the big three is pretty straight forward.
