Old 12-30-2011, 02:41 PM   #21
BlackV6
BlackV6 is on a distinguished road
Thank you Sir
Option 2 it is !!!!
BlackV6 is offline   Reply With Quote
Old 01-01-2012, 01:25 PM   #22
BlackV6
Any suggestions for a stripped rocker boss?
I have 3500 heads and an intake rocker threads on the head are stripped.
Do you think I can tap and use a 10 mm rocker from a 2000 -2005 3400
I can't be the first that has has this issue. Top is all buttoned down and if my idea will work it will save my butt.
PLEASE ADVISE AS I AM AT A STOPPING POINT AND I NEED YOUR ADVICE
thanks in advance
Old 01-01-2012, 01:32 PM   #23
unchained01
unchained01 is on a distinguished road
yeah you can do that or use a helicoil for the 8mm stud also there are a few threads on GAGT about it with pics
http://www.grandamgt.com/forum/showthread.php?t=84970
unchained01 is offline   Reply With Quote
Old 01-01-2012, 05:38 PM   #24
I would heli-coil it. It is quite common actually
Old 01-02-2012, 08:14 AM   #25
BlackV6
I you tubed heli-coil and now I just have to see who carries it and make sure no bits get into the motor. I should be able to mask it good enough . Ill post picks of the on motor "surgery" onece the patient is in post op .
