Old 04-08-2012, 07:32 AM   #1
mmorello82
mmorello82's Avatar
mmorello82 is on a distinguished road
Question Totally Lost Here! HELP!!
My car is having starting issues that is totally stumping me. When I get in the car, I turn the key to "on". All the idiot lights come on. When I move the key to "start", the car does nothing! All idiot lights go out (while I am holding it on "start") except the ses light. There is no noises at all that would suggest bad starter, etc. But if i either leave the car for a minute or turn the key a bunch of times, it'll fire right up. So becuase I am at a loss here, this is what I have done. I've replaced the auto-start relay in the fuse panel, just did the ignition swith yesterday (to no avail). I have tried putting the car in neutral to check the neutral safety swith, didn't help. I'm lost! Has anyone had this problem?? I need it fixed! Oh, also checked battery connections and starter connections. Thanks Guys!
mmorello82 is offline   Reply With Quote
Old 04-08-2012, 08:13 AM   #2
GBodyFreak
GBodyFreak is on a distinguished road
Bad battery cables?
GBodyFreak is offline   Reply With Quote
Old 04-08-2012, 09:10 AM   #3
check your grounds,
Old 04-08-2012, 06:38 PM   #4
Check to make sure you are getting power to the starter on both wires. the little wire should have power only with the key in "crank" and the bigger wire should have power all the time.
Old 04-08-2012, 11:50 PM   #5
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
do you hear your fuel pump starting up? if not its that, also the passlock in our cars is kinda funky sometimes turn the key to on does the bat light and security come on?
Hellfire5670 is offline   Reply With Quote
Old 04-09-2012, 04:22 AM   #6
mmorello82
mmorello82's Avatar
I checked the battery cables. I will check the cables at the starter though. When I turn the key on, the battery and Security light does come on. I saw in alldata that there is a groud attached to the bell-housing of the tranny that could be loose. When I get home from work, I think I'll check that too. Just trying to avoid a costly trip to the dealer!
Old 04-09-2012, 09:17 AM   #7
AGT
AGT's Avatar
Fuse
Have a good day
Old 04-09-2012, 06:43 PM   #8
mmorello82
mmorello82's Avatar
It starts if I turn they key about 20 times! lol
Old 04-09-2012, 07:25 PM   #9
could be a bad solenoid on the starter.
Old 04-10-2012, 04:31 AM   #10
mmorello82
mmorello82's Avatar
Hmmm. With no clicks.... or anything? I didn't really think of that. Figured that I'd hear some kind of noise....
Old 04-10-2012, 06:55 AM   #11
its possible. thats why if you check and you have power on those two wires at the starter EVERY time you turn the key to crank (not just after the 20th time) its the starter.
Old 04-10-2012, 12:02 PM   #12
Pull of the starter and test it.... Its like 3 bolts takes 10 miniutes
Old 04-11-2012, 04:24 PM   #13
mmorello82
mmorello82's Avatar
Now the challenge will be to have it do the problem while I have someone with me to put the key to "start" while I test the wires. It's an intermittent problem, so it's hard telling when it will happen again!
