Old 04-10-2012, 11:55 PM   #1
BAleroS
BAleroS is on a distinguished road
HID Low voltage question
The HID setup is a on a 2003 GLS. Drivers side works great, but the passenger side has sever low voltage. I have searched the forum, and haven't found anything specific to the year. So any input would be nice!
Thanks!
-1999 2.4L Alero, Bone Stock (sold)
-2003 3.4L Alero, Cleared Corners, Painted headlight bezels, Custom tail lights, painted interior bezels, chrome interior bezels,WAI,Flowmaster Super44 muffler(wrecked)
-2003 Honda CBR600RR, Yoshimura RS5 Slip on exhaust, Flush mount smoked turn signals (sold)
BAleroS is offline   Reply With Quote
Old 04-11-2012, 02:15 AM   #2
it could most likely be the ballast.
Old 04-11-2012, 06:57 AM   #3
how do you have them wired up? i had a bad connection on my old set up that would cause one of them to flicker and possibly go out a lot.
Old 04-11-2012, 08:28 AM   #4
BAleroS
Nope not the ballast, I have the drivers side working, and I tried both ballasts on it. Just too be safe, I replaced all stock parts on the light that wasn't working and it still didn't work. So I'm thinking there is a short somewhere.
I have them wired the same on both sides. So I don't know why that would cause it either.
Old 04-11-2012, 09:10 AM   #5
both my hids are wired up to the battery with a relay using the headlight power and ground as a relay control. yoru stick wiring harness just might not be able to handle the current of the hids.
Old 04-11-2012, 10:33 AM   #6
BAleroS
Alright, so could you tell me how you got that wired straight to the battery? or draw a diagram for it. Anything to help me know what to wire where. It would be much appreciated.
Old 04-11-2012, 11:58 AM   #7
Shiwnath
Shiwnath's Avatar
Google "9006 hid wiring harness" ... It's as plug and play as it gets.. Typically, HID ballasts tend to draw more power than the headlight wires can push through.. The harness uses the battery as its power source and the headlight voltage as a switch to switch your HIDs on and off... It uses an automotive relay to control the switching.. A relay uses a smaller voltage as a signal to switch on/off an higher voltage..
Old 04-11-2012, 12:21 PM   #8
go to ddm tuning and order the harness. nuff said.
Old 04-11-2012, 03:59 PM   #9
BAleroS
I have it for high beams lol, I'm doing all of them, but I wanted to get High beams since I use them the most, 50 mile commute a day on a lonely high way at night. So it would be a 9005 wiring harness.
Old 04-11-2012, 04:33 PM   #10
i just have low beam hids on mine. its just plugged into the stock harness
Old 04-11-2012, 04:43 PM   #11
BAleroS
That's what I was doing with the high beams. My drivers side works, but my passenger side isn't getting enough voltage. So I am going to try to direct current straight from the battery. Just ordered some Low beams too...
(I spend way to much money =( )
Old 04-11-2012, 08:09 PM   #12
yeah. i know what you mean lol. i only use lows cause my hids are bright enough that i dont need to use high beams
Old 04-11-2012, 08:31 PM   #13
colonel6632
colonel6632's Avatar
i have highs and lows in my car... love em
